Fuel level sending unit
- Tommotbird
26 Jan 2009 12:36 #260308
by Tommotbird
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
Fuel level sending unit was created by Tommotbird
Hi, I just had a gas tank for a KZ1100 shipped from the US to the UK and it is pretty good, including fuel cap & fuel level sending unit. It has a rubber hose attached to the black plastic cover of the sending unit. Can anyone enlighten me please as to the function of this hose and where it should be routed. It looks to me just like a drain hose but surely if the unit is seated correctly it should not leak.
Thanks Tommotbird
Thanks Tommotbird
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
- MFolks
- Thank you received: 540
26 Jan 2009 13:31 #260317
by MFolks
Replied by MFolks on topic Fuel level sending unit
I have the same set up on my 82 GPZ1100 B2. It is a safety type of drain so fuel does not get around an ignition source and cause a fire. If the gasket would fail the plastic housing and drain tube will allow the fuel to go to the ground.
- wiredgeorge
26 Jan 2009 16:49 #260378
by wiredgeorge
Replied by wiredgeorge on topic Fuel level sending unit
Most of the black covers w/hose are cracked and won't stay in place. I generally end up getting sick of trying to make it stay on the sending unit and just toss that piece. wg
