- Thank you received: 2098
Foul Mood
30 Jan 2009 15:54 - 30 Jan 2009 16:16 #260976
by Patton
Replied by Patton on topic Foul Mood
red.razor23 wrote:
Main Jet. Existing size might be okay. Would leave them as is until after resolving petcock and fuel level issues.
Imo the surest method for correct main jet sizing is sparkplug reading immediately after a high speed throttle chop. The ignition is simultaneously cut and clutch lever pulled in while coasting to a stop. The plug reading then shows what's happening inside the combustion chamber at full throttle (where main jet influences fuel mixture ratio.)
This of course presupposes that all other carb related matters are up to snuff, such as ample clean air supply, ample clean fuel supply, correct float levels, slide heights at wfo, PLUS good compression (valve clearances to specs), PLUS a good properly timed spark (all ignition components, coils, wires, plugs, wiring and connectors okay, good fully charged battery, etc.)
As known, even perfect as-new carbs can't compensate for deficiencies in other parts of the system.
Good Luck!
1981 KZ1000M1 CSR... original jet size is suppose to be #122.5R, and I have #117.5R installed (not by my hands). Now I'm not how sure how big a deal this is as I live at 3250' but I ride all year long from 0deg F to 100deg F....
Good Luck!
Last edit: 30 Jan 2009 16:16 by Patton.
30 Jan 2009 16:10 #260980
by Patton
If needed, here is the 1981 KZ1000 CSR carb diagram from kawasaki.com together with the part number information.
Good Luck!
[Click on image to enlarge view]
REF NUMBER PART NUMBER DESCRIPTION QUANTITY US CA CN REMARKS
220 220B0406 SCREW PAN HEAD 4X6 4
461 461F0500 WASHER SPRING 5MM 16
220A 220B0510 SCREW PAN HEAD 5X10 14
220B 220B0514 SCREW-PAN-CROS 16
11009 11009-1240 GASKET,CARB. PLUG 4
11009A 11009-1241 GASKET,FLOAT CHAMBER 4
11009B 16038-022 "O" RING 4
13169 13169-1190 PLATE, LOCK 4
14025 14025-1359 TOP-CHAMBER,MIXING 4
14043 14043-1010 FILTER,FLOAT VALVE 4
16009 16009-1085 NEEDLE-JET 4 X US
16009A 16009-1086 NEEDLE-JET (Canada) 4 X CN
16012 16012-1010 CAP-STARTER PLUNGER 4
16012A 16012-1011 CAP-STARTER PLUNGER 4
16014 16014-1014 SCREW-PILOT AIR 4
16016 16016-1019 PLUNGER 4
16017 16017-1086 JET-NEEDLE 4 X US
16017A 16017-1087 JET-NEEDLE (Canada) 4 X CN
16030 16030-1016 VALVE-FLOAT 4 X CN
16031 16031-1013 FLOAT 4
16055 16055-010 PLATE,NEEDLE 4
43028 43028-1025 4DIAPHRAGM,VALVE 4
92022 16034-001 WASHER MAIN JET 4
92037 16008-014 CIRCLIP 4
92043 16032-008 PIN,FLOAT 4
92055 92055-044 "0" RING 4
92055A 92055-1059 "O" RING,CHECK VALVE 4
92055B 92055-1105 "0" RING 4
92063 92063-1100 JET-MAIN,#A127.5 4 (RACING USE ONLY)
92063A 92063-1101 JET-MAIN,#A122.5 4
92063B 92063-1102 JET-MAIN,#A125 4 (RACING USE ONLY)
92063C 92063-1106 JET-MAIN,#A120 4 (RACING USE ONLY)
92063D 92063-1107 JET-MAIN,#117.5 4 (RACING USE ONLY)
92064 92064-1036 JET-PILOT,#A37.5 4
92066 92066-1051 PLUG,PILOT SCREW 4 X US
92066A 92066-1064 SCREW,DRAIN 4
92066B 92066-1086 PLUG,CARBURETOR 4
92066C 92066-1087 PLUG,PILOT JET 4
92081 16022-016 SPRING,PILOT SCREW 4
92081A 92081-1363 SPRING,DPHRGM VALVE 4
Good Luck!
