Need new petcock?
- twfields79
1978 KZ650 B2
- Thank you received: 2098
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
Might be a defective o-ring or valve gasket.
For illustration.
[Click on image to enlarge view]
Here's a better pic, being the 1980 KZ750 LTD as shown on kawasaki.com
- twfields79
1978 KZ650 B2
Cool thanks guys..... another question are the pod filters for the carbs all they are cracked up to be? And also will I have to rejet the carbs or just optional?
The "cracking" perhaps better describes earlier failure of carb holders due to increased stress (unless additional support is furnished at rear of carbs, too often neglected, imo).
And further enjoyment of:
Probable tuning difficulties throughout throttle range;
Performance sometimes diminished by cross-winds;
Propensity to ingest water during wet riding or washing;
Maintenance of additional air filter(s), instead of just one;
Expense of a good set, such as K&N's;
Re-routing crankcase breather hose.
But are more easily removed when disconnecting carbs from engine (when compared with old hardened airbox intake hoses), especially beneficial during the several r&r's frequently required incident to necessary re-jetting.
However, pods may sometimes be the only feasible option (where airbox has been removed). And are considered by many to look really cool.
Some well-respected pod proponents do indeed swear by them, especially toward seeking that last half-pony of power at top end. While many others prefer to just keep cruising along with the airbox as MaKaw intended.
Good Luck!
- Thank you received: 2237
BTW - My ZRX has pods, as does my KZ1000, and the only problem I have experienced has been power loss in severe cross wind (40mph+). Even so, my next bike will not have pods.
- timebomb33
you guy's have forgot one other problem with pods the tendenciy to loose you sidecovers.
And one of the most important.
All the more reason to fit security devises holding the side covers in place and keep them from blowing off (see other threads on the various methods).
