carbs manifold
- muffbumfy
carbs manifold
23 Feb 2006 04:07
had some good advice about purchasing some 34 cv carbs . george mentioned a need for bigger manifolds . does this mean the intake rubbers and what would be the best place to get the correct ones or does there need to be work done on head ports . also engine is standard z1b with a wisco 1075 bore kit but cams are stock what would be a good starting point for jetting . really appreciate this info gents this project has time so would like to get right .:blush:
- wiredgeorge
Re: carbs manifold
23 Feb 2006 06:14
Drop me a note offline if you need help with the carbs.
- roy-b-boy-b
Re: carbs manifold
23 Feb 2006 06:20
George got a great deal on some "J" boots at Mid-Ohio. Maybe he will pass them on. Roy
