- Thank you received: 1
CV-carb for Turbo?
- martijn
12 Jan 2009 07:34 - 12 Jan 2009 07:34 #257467
by martijn
CV-carb for Turbo? was created by martijn
Can I use a cv-carb when using the suck trough turbo set up??
Last edit: 12 Jan 2009 07:34 by martijn.
- timebomb33
- Thank you received: 10
12 Jan 2009 09:30 #257487
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic CV-carb for Turbo?
not a good idea think about the vacuam pulling on the slide and how you would be able to close it you need to use a mechanical throttle closing mechanisim.
- loudhvx
- Thank you received: 1616
12 Jan 2009 11:48 #257505
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic CV-carb for Turbo?
CV carbs still have a mechanical butterfly throttle. Usually the butterfly pivot is setup so engine vacuum wants to close the throttle.
The slide of a CV is just to reduce the effective size of the carb for lower throttle positions. After about half throttle, the slide should be wide open. Then the only factor is the butterfly throttle.
As for the turbo, I don't know how that would affect the operation of a non-turbo CV carb.
1981 KZ550 D1 gpz.
Other links.
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
12 Jan 2009 12:25 #257513
by tachrev
Build Thread
Replied by tachrev on topic CV-carb for Turbo?
As long as the carb is not pressurized(drawthrough), it should work the same. The only problem I could see is the fact the even after you chop the throttle the impeller still has some momentum, and will continue spinning, but the mechanical butterfly should still be closed.
I wouldn't know if this would cause a problem without trying it.
Pressurizing a CV carb in a blowTHROUGH setup, that I have no idea how it would work, but my first guess would be not well.
Build Thread
- Lorcan
- Speed Loony
- Thank you received: 59
16 Jan 2009 11:03 #258251
by Lorcan
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
Replied by Lorcan on topic CV-carb for Turbo?
CV carbs work very well on blow through setups. In fact I think the factory Yamaha 650 turbo had this arrangement.
760cc - 8.69@162mph
- tachrev
16 Jan 2009 11:20 #258252
by tachrev
Build Thread
That's really good to know, actually. Thanks!
Build Thread
- Jeff.Saunders
16 Jan 2009 11:35 #258254
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic CV-carb for Turbo?
Most of the CV carbs do not have a push/pull cable arrangement - just a pull cable. In the event you are under high boost, it is possible for the slide to get 'pinned' by air pressure to the carb body and not return.
I would not run one on any of my bikes. When I bought one of my first turbo bikes, it was the first thing I did - remove the CV carb...
Z1 Ent on Facebook,
- tachrev
16 Jan 2009 11:39 #258256
by tachrev
Build Thread
Wouldn't the mechanical butterfly still close the throttle in this case?
Build Thread
