1982KZ750 #1 cylinder not firing
- peterp411
10 Jan 2009 19:24 #257160
by peterp411
1982KZ750 #1 cylinder not firing was created by peterp411
Appears cylinder is not getting fuel. Cleaned all and rebuilt all carbs. All passages seem clear. Any ideas on next direction?
- MFolks
- Thank you received: 540
10 Jan 2009 20:08 #257171
by MFolks
Replied by MFolks on topic 1982KZ750 #1 cylinder not firing
How is compression on that cylinder? Drop the float bowl on #1 and see if there is a clog in a jet or passage. Do you have a fuel filter? And the condition of the tank,rusty?
Check for spark on that sparkplug also.
- peterp411
11 Jan 2009 03:51 #257202
by peterp411
Replied by peterp411 on topic 1982KZ750 #1 cylinder not firing
Removed float, jet is clear. Have good spark and yes have filter. Tank is somewhat rusty but fuel in bowl is clean.
Have not checked compression yet, will do later today.
Thanks.
Thanks.
- peterp411
11 Jan 2009 13:18 #257274
by peterp411
Checked compresion, 90, 100, 90, 110. They all seem to be reading low. Just did head gasket. Next I guess is valve clearance I assume. Any other ideas?
- MFolks
11 Jan 2009 13:25 #257276
by MFolks
Check condition of sparkplug ignition lead (Brit speak for high tension lead) and sparkplug cap (they have been known to fail under compression but spark good outside the engine).
