carb jeting
- ironleg
- its not what you ride its why
78 1000 ltd current project
75 z1 900 Dragbike 78 frame GS 1100 swing arm yamaha rear wheel dyna-s dyna 2 step best time 12.02 1.59 60ft
71 harley shovelhead chopper
2002 harley springer softail
1999 yamaha 600 grizzly
- Thank you received: 2098
i have a set of vm28ss off of a 75 z1 900 im cleanig and going through i also have a set of 78 kz 1000 vm26ss that are said to have a jet kit in them/ main jet-112.5/pilot jet-15/valve set-2.3 any point of puting any of this stuff in the 28's im going to put the 28's on my 78 1000 ltd:unsure:
Some carb info from Z1E:
28mm (VM28SC) Late Z1-A & all Z1-B
Main Jet 112.5
Air Jet 1.0
Needle Jet O-8
Jet Needle 5J9-2 (last number is the clip position)
Throttle valve (slide) 1.5mm cutaway
Pilot Jet 17.5
Air Screw setting 1 1/4 turns out
Good Luck!
VM26SS;
Main Jet 105R;
Needle Jet O-5/2;
Jet Needle 5DL31-3;
Pilot Jet 15;
Pilot Screw @ 1.0 turn out (+/- 1/.
Good Luck!
- roy-b-boy-b
- Thank you received: 103
The carbs had 17/112. That seems a 26mm set up. I then installed 20/120. Just right. Thay is with pods and headers.
- ironleg
- gane
[img][/img] 1977 KZ1000A1
- keith1
the 117.5 on the street yet as it is a winter wonderland here ......seems to be o k for getting it running and i have to get new throttle cables as the motion pros i have are not cutting it...i have nos cables coming and i should be able to dial it in a little more once they show up....
- mtkawboy
- Thank you received: 16
