- Thank you received: 104
using mikuni carb as throttle body
- PLUMMEN
08 Jan 2009 21:19 #256868
by PLUMMEN
using mikuni carb as throttle body was created by PLUMMEN
is it feasable to use a gutted out 38-42 mikuni carb as a throttle body just for the air supply side of a turbo motor while using seperate injectors plumbed into the turbos intake manifold for each cylinder with a computer to run it all?working on an old school looking turbo project but trying do do away with some of the old problems.
- tachrev
- Rubber Side Goes Down
- Thank you received: 11
09 Jan 2009 04:36 #256905
by tachrev
Build Thread
Replied by tachrev on topic using mikuni carb as throttle body
I would think you would need to figure out how to hook up a throttle position sensor, but beside that it should be possible.
Build Thread
