- Thank you received: 5
Mikuni BS34 float bowl?
- cnyl
04 Jan 2009 12:46 #256146
by cnyl
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
Mikuni BS34 float bowl? was created by cnyl
I'm trying to find a right side float bowl for my carbs. Drain screw was seized and by the time I got it out the treads of the bowl came out with it..:blush:
Are there any other float bowls that would fit other than the BS34's? I also posted a wanted add here.
Thanks.
Thanks.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
- snorules
07 Jan 2009 01:35 #256527
by snorules
1980 KZ550C (daily rider)
1981 KZ1000J (bagger project in progress)
1981 GS1100 (future dragbike)
1978 Z1R (not mine yet, but trying to work out a deal to acquire it).
Replied by snorules on topic Mikuni BS34 float bowl?
If all else fails, clean out the hole really well, fill it with JB weld. After it dries completely, you can drill and tap a new hole. Either that or helicoil it. If you can find one, a new one would be ideal though. Let me check around the shop and a few other places, I might be able to round one up.
Sarge
Sarge
- cnyl
07 Jan 2009 05:00 #256536
by cnyl
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
Replied by cnyl on topic Mikuni BS34 float bowl?
Thanks sarge! Part of the case around where the screw goes in broke off so i'll need to find a new one.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
- Jack
- Thank you received: 7
07 Jan 2009 10:20 #256564
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic Mikuni BS34 float bowl?
Try
www.sudco.com
for Mikuni carb parts.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- adamnphx
11 Feb 2009 21:32 #264011
by adamnphx
76 kz900, 81kz1000, 66 triumph chop
Replied by adamnphx on topic Mikuni BS34 float bowl?
hey did you find another bowl yet? if not email me. i got a spare set of carbs i'll send you one. awood_3379 at yahoo
adam
adam
