any reason to NOT use allen heads...
  • wireman
  • wireman's Avatar
Re: any reason to NOT use allen heads...
22 Feb 2006 13:04
#25656
fastenal just called me back,hes got a 100 of them in a box waiting for me but theyre not plated looks like im off to the plater,ill save 8 of em for you solomrus!;)
  • solomrus
  • solomrus's Avatar Topic Author
22 Feb 2006 13:08
#25657
roxor!
you live down in b-vue, right? i've got class at metro SOC tonight at 1800. could hook up w/you before if you are close.
--r
198o kz1ooo Bravo Four
  • wireman
  • wireman's Avatar
22 Feb 2006 13:11
#25658
do you want to wait till i take em to the plater,or do you just want them black?what class are you taking down there?ive got some stainless steel 8mm allthread 5' piece and stainless steel nuts i bought to to make stainless steel exhuast studs also,ill set ya up with some of that also!
Post edited by: wireman, at: 2006/02/22 16:12
Post edited by: wireman, at: 2006/02/22 16:18
  • solomrus
22 Feb 2006 13:26
#25661
black is totally cool by me.
i've got 8mm studs on the street motor, need some 6mm ones for the turbo motor. could cut them to length for you if you need.
just finishing up winter term for TIG welding. finished up the lab work and all for steel that i was doing, now i am burning up as much aluminum in the last couple classes i can. not doing too badly at it.
--r
  • wireman
  • wireman's Avatar
22 Feb 2006 13:30
#25662
which part of building are you in,by the plumbing classes east building?
  • solomrus
22 Feb 2006 13:33
#25663
yup, east building.
if you go in the back, go down to the crotch of the L in the building, there is a sign that says WELDING LAB. i park out back, and go in that door most of the time.
--r
  • wireman
  • wireman's Avatar
22 Feb 2006 13:35
#25664
look for a blue ford van with hye tech utilities plastered all over it,ill try and be there around 5:30;)
  • solomrus
22 Feb 2006 13:44
#25666
right on man.
see you then.
--r
  • wiredgeorge
  • wiredgeorge's Avatar
22 Feb 2006 13:51
#25671
I use 6x16mm w/1.0 pitch thread socket head stainless and have never stripped a thread. You do know that a torque wrench can be used with a socket head? I buy these by the box of hundred specifically for this purpose.
  • solomrus
22 Feb 2006 14:34
#25688
i'm down with that. 8^)
solomrus wrote:
it's far easier to use a tq wrench on an allen head fastener, than on a phillips head. 8^)
--r
--r
  • IowaKZ
  • IowaKZ's Avatar
  • '80 G1 Classic
22 Feb 2006 18:09
#25731
Ok, dumb question? What is the anti-sieze for on the allen heads?
I have alway cursed the phillips and am going to replace my screws over time. I just need to decide black or plated.
1980 G1 Classic
Bettendorf, Iowa
  • wireman
  • wireman's Avatar
22 Feb 2006 18:22
#25735
anytime you screw or bolt two differant kinds of metals together you get electrolysis or a chemical reaction between the two metals the antiseize acts as an insulator and makes it easier to take back apart later,and helps lube the threads.;) goodluck,happy wrenching!
