plugging vacuum ports on carbs
  • Muddy
  • Muddy's Avatar Topic Author
02 Jan 2009 08:20
#255764
What is the best way to plug the vacuum ports on carbs that go to the smog equipment and vacuum petcock?
  • OKC_Kent
  • OKC_Kent's Avatar
Re: plugging vacuum ports on carbs
02 Jan 2009 09:08
#255768
You can buy rubber caps at the auto store in various sizes for just a few bucks a package. I think 7/32" is the size for the intake manifold ports, carb ports may be the same. Measure yours.
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
  • wiredgeorge
  • wiredgeorge's Avatar
02 Jan 2009 10:55 - 02 Jan 2009 10:56
#255777
wgcarbs.com has quit using rubber vacuum plugs sold at autoparts store because the tend to harden and crack quickly... a month or two at best. We buy vinyl plugs of the same size as Kent mentioned and these last indefinitely. If you can't find vinyl, use the big vacuum port plugs meant to be used on vacuum fittings on carb holders for the VM series carbs. Z1Enterprises.com sells those and they won't crack.
Last edit: 02 Jan 2009 10:56 by wiredgeorge.
  • kz1000kltd1982
  • kz1000kltd1982's Avatar
03 Jan 2009 07:55
#255882
Go to Lowes and in the hardware drawers you will find WHITE caps that are the correct size and fit snug. five caps for a buck, mine has been on for 2 years with no problems
