- Thank you received: 48
KZ650 General Carb Questions
- JMKZHI
The 81 650 gets 62 hp. The 82-83 models get 67 hp.
I'm fairly sure the primary difference between the bikes is the carburetors: the later CSRs have Mikuni BS32 carbs. The stock VMs are known to be jetted lean from the factory. (1) Is the same thing true of the BS carbs?
(2) Any idea how much the hp is bumped up after rejetting either type?
The KZ750-4s have the BS34 carburetors.
I'm fairly certain these will physically fit the 650:
the airboxes & carb holders are the same as on the 82 CSR.
(3) From a carburetion perspective can these be used on the KZ650?
Particularly for those who have the aftermarket exhaust &/or pod filters:
(4) Wouldn't it make sense for them to get some BS32 (or BS34) carbs?
Thanks for any input.
- steell
Only the GPz750 models have the BS34's, all the rest use CV34 Keihin carbs.
Hmm, I think maybe the 750L used BS34's also, it was sort of a standard GPz
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- mariozappa
- Thank you received: 8
I ran a set of CV34's on my B1 for years. Just use the CV carb holders.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- rdgrnr
The answer to your question about bigger carbs is YES! I replaced the stock vm24 carbs on my 77 with vm26 carbs from a GS750. I've never had the bike on a dyno so I don't know HP numbers, but the gain was extremely noticable. You could easily replace with stock carbs from a kz750, or even find a set of vm26 or vm28 from a kz900 or 1000 (or GS750).
Can the 26 pumpers run on the 650B1 with stock exhaust and airbox? Or would it run too rich?
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
- anarki650
09 Kawasaki ER6n
Omaha NE
