Vacuum Petcock Line
- Muddy
01 Jan 2009 06:45 #255636
by Muddy
Vacuum Petcock Line was created by Muddy
My cafe has a tank with daul manual petcocks. Do I need to plug the vacuum line from the carbs?
- Thank you received: 2098
01 Jan 2009 06:59 #255640
by Patton
Replied by Patton on topic Vacuum Petcock Line
Muddy wrote:
Yes, with manual (non-vacuum operated) petcock, all carb vacuum ports should be plugged (capped) during normal operation. The vacuum ports are used when synching the carbs.
Click here for > Vacuum Plugs from Z1E
Good Luck!
Good Luck!
