Running Rough??
- 81KZ
01 Jan 2009 04:52 #255635
by 81KZ
Running Rough?? was created by 81KZ
My 81KZ 650 CSR is running really rough,,I`ve had the gas tank "re-lined", carb`s cleaned, just at a loss,,
Any help on what the culprit(plugs?) might be would be really appreciated,
Thanks
Thanks
- Thank you received: 2098
01 Jan 2009 06:48 #255637
by Patton
Replied by Patton on topic Running Rough??
No eBay APP ID and/or Cert ID defined in Kunena configuration81KZ wrote:
Hello, Ron, and WELCOME to KZrider!
We're glad you're here!
Four brand new NGKB7ES sparkplugs would be as good a place to start as any.
If not already at hand, am thinking a shop manual would be most helpful.
Here's one of several current ebay listings.
Good Luck!
Thanks
Good Luck!
- trianglelaguna
- Thank you received: 235
01 Jan 2009 07:18 #255643
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Running Rough??
welcome.....ditto on the shop manual.....did you clean the carbs .....cuase i missed some stuff the first couple of times on mine and when they were finally done right...a.world of difference....good luck.....
1976 KZ900
2003 ZX12R
2007 FZ1000
- kz1000kltd1982
03 Jan 2009 08:08 #255883
by kz1000kltd1982
Replied by kz1000kltd1982 on topic Running Rough??
always check the intake rubbers many have gotten old and have cracked between the mounting flange and the rubber letting your carbs suck to much air. Also I would sugest a compression check bad rings or valves could be a issue they should have at least 115 pounds of compression to have power and a good running bike it can run with lower or higher compression I think the new engine compression is around 130 or 150 PSI. I use B-12 carb liquid cleaner in the gas to clean the carbs along with B-12 spray to clean anything I can get to, I have found to use both will do a better job cleaning because the spray is there for a short time and what is in the gas will keep working while the gas is running through on a normal path hitting all spots the spray missed
