need advise of carbs fitting to 1977 KZ1000
- addycml
28 Dec 2008 23:57 #255204
by addycml
need advise of carbs fitting to 1977 KZ1000 was created by addycml
Hi, Dose anyone know this carbs I buy from ebay do fit a 1977 KZ100?
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...B:EOIBSA:MOTORS:1123
Item number: 230315462050
It seem look a bit different i see before.
- Thank you received: 2098
29 Dec 2008 00:35 - 29 Dec 2008 01:14 #255208
by Patton
Replied by Patton on topic need advise of carbs fitting to 1977 KZ1000
Here's a link to some carb information from Z1E's website.
Carb i-d guide
The ebay carbs look like the early model Z1 carbs (two screws holding the cap and exposed spring at top) after the change from single large bottom-located floatbowl drain screw to smaller side-located floatbowl drain screw and bottom-located overflow nipples.
Am guessing the ebay carbs are 28mm from an earlier model that had perhaps been fitted to replace oem 26mm carbs on a KZ1000.
Good Luck!
Carb i-d guide
Good Luck!
Last edit: 29 Dec 2008 01:14 by Patton.
- arai59
- Banned
- Thank you received: 1
29 Dec 2008 17:50 - 29 Dec 2008 17:54 #255296
by arai59
Replied by arai59 on topic need advise of carbs fitting to 1977 KZ1000
Those 28 carbs are off an early Z. They can work but a set of later Mikuni 26's or 28's would be good also. One thing though...those early carbs work really well.
Last edit: 29 Dec 2008 17:54 by arai59.
- snorules
07 Jan 2009 00:42 #256523
by snorules
1980 KZ550C (daily rider)
1981 KZ1000J (bagger project in progress)
1981 GS1100 (future dragbike)
1978 Z1R (not mine yet, but trying to work out a deal to acquire it).
Replied by snorules on topic need advise of carbs fitting to 1977 KZ1000
I'll be putting a nice set of 29mm smooth bores off of a 78 Z1R on ebay as soon as I finish rebuilding them, for a little less money, I also have a set of BS34's and a set of VM28's of of a 77 KZ1000 I'm in the process of working on also. shoot me a PM, maybe we can work out a deal.
Sarge
Sarge
