Are these the right jets ??
- triggerbilly
22 Dec 2008 02:39 - 22 Dec 2008 02:42 #254055
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
Are these the right jets ?? was created by triggerbilly
OK i've just put pods onto my 1982 kz 750-e3
I just wanna check if these are the right jets to order
here is the link to the mains....
www.z1enterprises.com/detail.aspx?ID=1928
and the pilots are......
www.motorcyclecarbs.com/KEIHIN_PILOT_JET_N424-25_40_P4746.cfm
I think they are right from what i can make out
I just need to double check
thanks
Trigger
thanks
Trigger
1982 kz750-e3
1983 cb1000c
plano. TX
Last edit: 22 Dec 2008 02:42 by triggerbilly.
- wiredgeorge
22 Dec 2008 07:17 #254090
by wiredgeorge
Replied by wiredgeorge on topic Are these the right jets ??
The pilot jet you show is significantly shorter than the pilot jet used in the CV34 and won't work. The main jets are correct.
- triggerbilly
22 Dec 2008 14:53 #254174
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
Replied by triggerbilly on topic Are these the right jets ??
Yeah i thought the pilot might be wrong.
any ideas which one i do need ???
1982 kz750-e3
1983 cb1000c
plano. TX
- wiredgeorge
22 Dec 2008 16:10 #254191
by wiredgeorge
I don't think you will find them. I have never seen them on a Keihin pilot (slow) jet list and don't even know their Keihin part number. If you bump up the main jet size to a 68 or 70 it will do nicely compensating. 140 secondary mains will be about right.
- triggerbilly
22 Dec 2008 16:15 - 22 Dec 2008 16:21 #254193
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
so i just change the mains then, and leave everything else alone ?
forget that ......
i just looked at the diagrams and see i need the 140 2nd jets now !!!
forget that ......
1982 kz750-e3
1983 cb1000c
plano. TX
Last edit: 22 Dec 2008 16:21 by triggerbilly.
- wiredgeorge
22 Dec 2008 16:20 #254195
by wiredgeorge
I think that it has already been mentioned you will need to change the pilot jets. I would try about a 140 main and 47.5 pilot jets to start. I have another way of rejetting the 750 BS38s so I don't know what jets will be needed nor does anyone else as there have never been a really good source of main jets. Buy a bunch of jets and experiment as shipping will be more than the jets I suspect. The pilot jets are available at z1enterprises.com and are type Mikuni BS30/96 and will be cheaper to buy here in the states.
- triggerbilly
22 Dec 2008 16:37 #254198
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
OK
sorry for all the dumb Q's
so are these right ....
www.motorcyclecarbs.com/MIKUNI_PILOT_JET..._47_5_P10376C798.cfm
I'm pretty confused now
so i need to order ..
mains #140
pilots MIKUNI PILOT JET BS30/96 #47.5
what about secondary mains ???
HELP I'M A DUMB-ASS !!!!!!
mains #140
1982 kz750-e3
1983 cb1000c
plano. TX
- triggerbilly
23 Dec 2008 23:19 #254401
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
So are these the right ones ?
secondary's.......
and mains........
www.motorcyclecarbs.com/KEIHIN_MAIN_JET_...-393_70_P4613C78.cfm
secondary's.......
and mains........
1982 kz750-e3
1983 cb1000c
plano. TX
- wiredgeorge
24 Dec 2008 06:46 #254424
by wiredgeorge
Have you looked at your main jets? The jet pictured in the 2nd link is NOT a main jet in the sense that you need. It is a secondary main jet and won't work. Your "main" jet is a barrel shaped affair. They are a bit difficult to find.
- triggerbilly
24 Dec 2008 11:35 - 24 Dec 2008 11:36 #254498
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
Does anyone out there know where i can find these
barrel shaped affair's !!!
seriously thinkin of buying some new airbox hose/ducts and going back to the box !!!
1982 kz750-e3
1983 cb1000c
plano. TX
Last edit: 24 Dec 2008 11:36 by triggerbilly.
- jmargrav
24 Dec 2008 14:42 - 24 Dec 2008 14:43 #254518
by jmargrav
1982 KZ750-E3
Lariamie Wyoming GO WYO!
Replied by jmargrav on topic Are these the right jets ??
HI, I have the same bike and went through the same thing that you are right now, these jets are hard to find but i ordered mine from SUDCO, about $30 including shipping for four of them. I will try to link the page but have never done it before.
www.sudco.com/keihinjets.html
2nd to last jet on the bottom of the page, 8.5 mm, slow air jet
1982 KZ750-E3
Last edit: 24 Dec 2008 14:43 by jmargrav.
- triggerbilly
24 Dec 2008 15:43 #254525
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
Thanks alot
that's a BIG help
I guess the pods still have a chance now !!!!
that's a BIG help
1982 kz750-e3
1983 cb1000c
plano. TX
