KZ1075 9 to1 compression air box vm26
- farkwar
21 Dec 2008 13:15 #253924
by farkwar
78 kz1000 B2 LTD 1075cc 9 to 1 compression
02 ZG1000
95 KLR
03 EX500
KZ1075 9 to1 compression air box vm26 was created by farkwar
Hello every one,thank you for your time spent on this web site.I have a 78kz 1000B2 that I am puting a 1075 kit in,this is my 1st motorcycle rebuild.The kit has 9 to 1 compression.I have vm26 carbs and plan on using the stock air box with a k&n filter.I live at 300 feet above sea level and dont plan on going over 5000 above sea level.The carbs have 15 pilots and 110 mains,will this size jets work or will it melt?What size jets would be best?
PS 4 in to 2 mac exhaust
Thank you
Thank you
02 ZG1000
95 KLR
03 EX500
- keith1
- Thank you received: 2
21 Dec 2008 16:14 #253962
by keith1
Replied by keith1 on topic KZ1075 9 to1 compression air box vm26
farkwar wrote:
definitely a good question for wired george to answer.....a lot of variables....
Thank you
- wiredgeorge
22 Dec 2008 07:20 #254091
by wiredgeorge
Replied by wiredgeorge on topic KZ1075 9 to1 compression air box vm26
Give it a try with the jets you have. The 78 VM26 is lean from the factory and it would not hurt to install some #17.5 pilot jets, clip to 4th slot and I personally would thing some somewhat larger mains would work a bit better with the kit you have... perhaps #115s.
- farkwar
28 Dec 2008 10:46 #255095
by farkwar
02 ZG1000
95 KLR
03 EX500
Replied by farkwar on topic KZ1075 9 to1 compression air box vm26
Thank you
parts ordered
parts ordered
02 ZG1000
95 KLR
03 EX500
