- Thank you received: 337
Petcock For the Kz750B Twins?
- bountyhunter
17 Dec 2008 21:39 #253334
by bountyhunter
Petcock For the Kz750B Twins? was created by bountyhunter
Anybody know what new petcocks will fit onto the fuel tanks for the older KZ750B series twins?
I realize it probably will have only one outlet and need a splitter, but does anything screw onto the tank pipe as is?
- wiredgeorge
18 Dec 2008 05:44 #253363
by wiredgeorge
Replied by wiredgeorge on topic Petcock For the Kz750B Twins?
If the tank has a bung, it will be a 22mm bung and you can buy an aftermarket petcock from Z1Enterprises.com... either the less expensive type or a Pingel.
- bountyhunter
18 Dec 2008 15:07 #253418
by bountyhunter
Replied by bountyhunter on topic Petcock For the Kz750B Twins?
Thanks, I will check the 22mm petcocks.
- steell
18 Dec 2008 17:00 - 18 Dec 2008 17:11 #253447
by steell
Replied by steell on topic Petcock For the Kz750B Twins?
Found one at Z1 that should fit and has dual outlets. Problem is it's ~$105.00 !!
www.z1enterprises.com/detail.aspx?ID=28
Last edit: 18 Dec 2008 17:11 by steell.
- Locozuna
18 Dec 2008 18:25 #253456
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic Petcock For the Kz750B Twins?
Whew! But as they said about the suits in Men in Black.... Last one you'll ever need...or was that own? I don't know how much cheaper the single outlet ones are but they are high flow and teeing one might be cheaper.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- bountyhunter
18 Dec 2008 18:51 #253461
by bountyhunter
The two outlets 180 across from each other would be a real pain to try to fit in, the one I have is 90 degree offset. A single outlet with a split would actually be a lot easier to fit in for me.
- bountyhunter
18 Dec 2008 23:36 - 18 Dec 2008 23:39 #253498
by bountyhunter
This one looks too good to be true. Anybody know if these are any good?
At that price you could buy a new one every year.
www.z1enterprises.com/detail.aspx?ID=1745
Petcock - Custom Chrome - Single Outlet 22mm thread nut
TU49-2873
Engineered and designed to eliminate all internal O-rings. The innercore design insures against gas leakage while providing maximum flow. Features a filter screen, reserve setting, and chrome body. Side facing output nipple.
$14.29
TU49-2873
$14.29
Last edit: 18 Dec 2008 23:39 by bountyhunter.
