- Thank you received: 5
KZ650 with Asthma
- anarki650
20 Dec 2008 07:04 #253648
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic KZ650 with Asthma
The airscrews should be where they need to be. I've had carbs where the airscrews were only just past 1/4 turn out, no big deal.
Good to hear you're getting everything figured out!!
09 Kawasaki ER6n
Omaha NE
- KawiConvert
- Thank you received: 4
20 Dec 2008 08:10 - 20 Dec 2008 08:16 #253658
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic KZ650 with Asthma
HerrDeacon wrote:
It seems to be gone. I need to get the bike un-nonopped and then do some more rides to verify, but it felt like I had good response over the whole range. It takes off from a stop well, though I haven't really spun it up and tried to launch. And while in 5th I would let it slow down enough to need almost the entire throttle range and then crank it and let it speed back up. It did fine and pulled through the entire range so for now I am happy.
Oh, the needle clip is in the 4th groove from the top now.
Thats great to hear KC. Is the flat spot gone as well now?
Where do you have the needle clipped now?
Last edit: 20 Dec 2008 08:16 by KawiConvert.
- KawiConvert
20 Dec 2008 08:14 #253660
by KawiConvert
anarki650 wrote:
I am glad to hear I can get away with a single turn. I am glad to hear that I won't have another night of tearing apart my carbs to try something else.
On a side note, for synching my carbs, can I take all 4 top covers off at once? I ask this because my slides all have a small hole 90 degrees off of the two mounting holes that goes through the top of the slide. Or do I only take off the top to adjust the slide height?
Thanks,
KC
Thanks,
KC
- anarki650
20 Dec 2008 08:48 #253667
by anarki650
09 Kawasaki ER6n
Omaha NE
Here's a link to a bunch of maintenence how to write ups for the 650. It's got a great write up on bench syncing carbs. Final sync is done with the top covers all off and a manometer, you'll do best if you have a shop fuel cell (hanging bottle) for this because you need to have the tank off in order to sync the carbs.
maintenance.kz650.info/GeneralMaintGuides.htm
09 Kawasaki ER6n
Omaha NE
- KawiConvert
20 Dec 2008 09:26 #253675
by KawiConvert
Thanks for the link. Next week I'll have time to pull the carbs off and get things finalized on my bike. I may even have a seat made.
