Fuel Tank Petcock
- eaglecrash2
16 Dec 2008 18:30 #253107
by eaglecrash2
'77 kz650,'06 Vulcan 500ltd, '07 ducati 1098s, '03 bmw m3, '85 carrera, '71 911s, '06 s2000, '03 suburban, '76 triumph TR6
sold: '69 honda 250, yr(?) 50cc honda moped, '52 Beechcraft Bonanza
Long Beach, California
Fuel Tank Petcock was created by eaglecrash2
Anyone knows where I can buy a replacement for my 77 kz650? It's not shutting off the fuel completely.
- Old Man Rock
- Thank you received: 225
16 Dec 2008 18:43 - 16 Dec 2008 18:44 #253114
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Fuel Tank Petcock
Not sure which model your speaking of for that year....
Z1 Enterprises...
www.z1enterprises.com/catalog.aspx?pid=KZ650-B1-1977-CF0
www.z1enterprises.com/catalog.aspx?pid=KZ650-C1-1977-CF0
OMR
Z1 Enterprises...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 16 Dec 2008 18:44 by Old Man Rock.
- Locozuna
16 Dec 2008 18:44 #253115
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic Fuel Tank Petcock
If ya don't care about original and want the best get a Pingle. Few more bucks but by far the best.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- H2RICK
- Is this a fun bike, or what!!!
- Thank you received: 1
16 Dec 2008 18:54 #253121
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Fuel Tank Petcock
If it's a Mikuni petcock then you have a good shot at getting a repair kit for it c/w diaphragm and all the rubber bits.
If it's a Taiyo Gikken petcock then you've got problems. There are very few kits available for the TG petcocks.
If there IS a kit available for your particular petcock then they usually retail in the US$20-$30 range depending on who is selling it.
Of course there may be a salvage yard in your area with a suitable replacement.....
- eaglecrash2
16 Dec 2008 19:10 #253127
by eaglecrash2
Replied by eaglecrash2 on topic Fuel Tank Petcock
Thanks folks. I have a '77 kz650B model. I don't know the kind of petcock I have. Is it labeled? I'll have to look closer tomorrow. I do remember when I took it apart that it has like a tapered cork-like valve. Maybe you folks are familiar with it. I checked out the Pingel site and looks like that's the way to go. Looks like I need to get some sort of adapter as well. Wow, looking forward to not having to clean that fuel spot under the bike every time! Thanks!
- bill_wilcox100
- Thank you received: 5
16 Dec 2008 20:24 #253138
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Fuel Tank Petcock
EC2, remember... order one of Z1 Ent.'s inline fuel filters as well. Don't rely on the filter built into the OEM Petcock. Don't ask. :blush:
Best of success.
Best of success.
Upgrades:
Montreal, Canada
- eaglecrash2
16 Dec 2008 22:19 #253150
by eaglecrash2
Yes, I'd already installed an in-line filter prior. The mesh has a small hole in it. Thanks.
- image
18 Dec 2008 20:43 #253479
by image
Replied by image on topic Fuel Tank Petcock
hi all,
thought i'd ask this here rather than start another thread...
i have an '81 kz750-4 ltd, with a petcock that works but a tank that's pretty rusty. i've managed to find a gem of a replacement tank at the local wreckers, but one of the bolt holes for the petcock has had the bolt snapped off in it and partially drilled out. what is my best course of action if i get this tank? try and re-tap the thread in the bolt hole and fit the original petcock? from looking at most of the pingel ones (and other brands) i've seen, they don't seem to utilise these bolt holes anyway...or do they - is that what the adaptor plate is for?
all advice most appreciated guys, cheers.
- H2RICK
18 Dec 2008 20:57 #253480
by H2RICK
Yep, most of those aftermarket replacement petcocks use an adapter plate. The petcock itself screws into the plate and then the plate bolts to the tank with the stock bolts. All you need to know is your stock bolt size (usually 6mm) and the centre-to-centre distance between the bolt holes (usually something like 32mm, 35mm, etc).....
but to use the adapter plates you have to have TWO good bolt holes in the tank. So it looks like you'll have to fix that busted/stuck bolt either way....old petcock or replacement petcock.
- image
18 Dec 2008 21:31 #253484
by image
crap...i feared as much. think it's worth it though, this tank really is pristine other than the bolt prob.
