- Thank you received: 2
ARE THESE 28 MM 'S...?
- keith1
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...em=#ebayphotohosting
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- keith1
if they are like he says that they came off of a z1-r then they are 28 mm carbs hard to tell from the pictures thou.
I THINK THE SINGLE FEED IS A 28 MM TRAIT....BUT I M NOT SURE...IF THEY ARE WHAT HE SAYS, I WOULD GRAB THEM AND HAVE GEORGE DO A REBUILD......
- timebomb33
- Gman
- Thank you received: 5
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
- Thank you received: 2098
- keith1
those be the ones.....
These carbs were oem (factory stock) on 1978KZ1000-D1 (cafe racer), 1979KZ1000-A3 (standard model), and 1979KZ1000-D2 (cafe racer), and perhaps others.
Being manual slide (not CV), I consider such carbs user friendly and easy to get along with. The listed carbs appear clean, but that's usually impossible to really know without actual disassembly and inspection, unless lucky enough to get bolt-on perfect performers.
Good Luck!
- keith1
Could be wrong, but didn't think these Mikuni VM28SS carbs were really all that "rare" as touted in the listing. Other members will likely know more about how readily available these carbs might or might not be.
Good Luck!
i would buy these expecting to rebuild....i would guess my throttle cables would work and i think they would use the same manifold boots ...we ll see what happens.....
