Gas Tank Loose ---- 1980 KZ50 LTD
- mattsand
12 Dec 2008 11:09 #252225
by mattsand
Gas Tank Loose ---- 1980 KZ50 LTD was created by mattsand
The gas tank on my 1980 kz550 ltd is loose at the front. Extremely loose, can move it easily side to side, and can lift it off the frame easily. I'm not really seeing a way to lock in place completely, I see the knobs on the front that the tank moves onto, but it in no way holds tight.
Any comments or suggestions would be very welcome. I've about got the bike ready to run, but I would be far too nervous to try to run it like this.
Thanks for helping the newbie!
- mariozappa
- Thank you received: 8
12 Dec 2008 11:36 #252227
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic Gas Tank Loose ---- 1980 KZ50 LTD
Do you have the rubber grommets on the knobs?
1977 KZ650C1
- mattsand
12 Dec 2008 11:39 #252228
by mattsand
Replied by mattsand on topic Gas Tank Loose ---- 1980 KZ50 LTD
There are no grommets on the knobs or the tab on the back.
- timebomb33
- Thank you received: 10
12 Dec 2008 11:43 #252229
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Gas Tank Loose ---- 1980 KZ50 LTD
you must have them in place to prevent your problem from happining
- MFolks
- Thank you received: 540
12 Dec 2008 11:55 #252230
by MFolks
Replied by MFolks on topic Gas Tank Loose ---- 1980 KZ50 LTD
Go to
www.z1enterprises.com
and see if they can help you get the parts for your tank.
- Thank you received: 2829
12 Dec 2008 12:44 #252233
by 650ed
Replied by 650ed on topic Gas Tank Loose ---- 1980 KZ50 LTD
According to Kawasaki.com you need the following rubber bits, and they are still available. Take a look at their parts diagram. I’ve shown pricing from Ron Ayers in case Z1E doesn’t have them.
92075-101 Damper, rubber fuel tank (front - you need 2)
$2.54 ea.
92075-295 Damper, rubber fuel tank (rear - you need 1)$2.91 ea.
$2.54 ea.
- mattsand
12 Dec 2008 19:33 #252281
by mattsand
Fantastic info all around, once again. Love this board
- JR
- Thank you received: 449
13 Dec 2008 06:51 - 13 Dec 2008 06:52 #252333
by JR
Replied by JR on topic Gas Tank Loose ---- 1980 KZ50 LTD
mattsand wrote:
If the tab on the back is also missing then you cant bolt it to the frame and it will likely slide around some. My tab broke off a few years ago and I stuck it on using PC 7. I dont do welding and even if I did I thik I'd want to be very carefull trying on a gas tank :laugh:
Can you rig something up here ?
Edit
I probably misunderstood. grommets missing not tab
Edit
Last edit: 13 Dec 2008 06:52 by JR.
- Thank you received: 2098
13 Dec 2008 07:15 - 13 Dec 2008 07:25 #252338
by Patton
Replied by Patton on topic Gas Tank Loose ---- 1980 KZ50 LTD
Am guessing item #16 is the rubber damper at rear of tank under the tab.
The two item #15 are the grommets on both sides that fit onto frame studs and slide into place against the tank when the tank is installed.
See above post by 650ed for Kaw inventory part numbers.
[Click on image to enlarge view]
Good Luck!
Good Luck!
Last edit: 13 Dec 2008 07:25 by Patton.
