79 KZ1000 LTD B3 (continued)
- lrburke
11 Dec 2008 19:22 - 11 Dec 2008 19:25 #252098
by lrburke
79 KZ1000 LTD B3 (continued) was created by lrburke
Hey guys, Just finished up a set of carbs on a 79 KZ 1000 LTD. I put a new accellerator pump kit in and made absolutely sure all the little passages in the system are clear. All the little check valves are in place with new o-rings between the discharge nozzles and float bowls. Even that little tiny hole is clear. Can't seem to get it to pump! Am I missing something? Thanks for any suggestions!
Last edit: 11 Dec 2008 19:25 by lrburke. Reason: more understandable
- PLUMMEN
- Thank you received: 104
11 Dec 2008 20:12 #252114
by PLUMMEN
Replied by PLUMMEN on topic 79 KZ1000 LTD B3 (continued)
is the pump linkage moving when you open and close throttle? i havent messed withose in years but from what i recall theres not much to them other than adjusting the rod.are you getting fuel into the carbs?
