Jetting for pods; good place to buy jets
- kzcody
20 Feb 2006 18:43
Hi everyone, quick question about jets and where to buy em. I'm going to put pods on my 440 lt A1 and I read on a site that a good rule of thumb is to go up 2 jet sizes. Now is that for both the main and secondary jet? and also where is a good place to buy a set of jets so that I can tinker with the adjustments. I realize they're expensive but I trust you guys to know a good place. Thanks!
-Cody
-Cody
- ronkz1000
Re: Jetting for pods; good place to buy jets
21 Feb 2006 06:45
www.z1enterprises.com/
I bought mine here plus some more carb parts like O rings B)
- kzcody
23 Feb 2006 17:24
ok so i just pulled the jets off my carbs to find out the number on them. Turns out they're 88. If I'm putting pod filters on do I upgrade to a 90 or a 92. also as far as the primer jet goes i think it said 52 although it was so old it was hard to read. do i up those too? and by how much?
thanks
cody
thanks
cody
- The Fish
26 Feb 2006 08:49
There are too many variables to say "this is exactly what you will need". Varibles like altitude, temperature, riding style and so forth. The best jetting is done "seat of the pants".
Sometimes you can get away with just putting a larger main jet in, some times you may need a bigger primary jet and some carbs will need the jet needle raised.
Start with your stock jetting and go up 1 size at a time.Buy the next 3 sizes bigger main jets and the next size bigger primary jet.
I would imagine that others on the board would have a simular set up on their bike and would post their findings.
This is a very general description of how most carbs work.
The primary jet controls the amount of fuel at idle and up to 1/4 throttle. Installing a larger primary jet would richen the mixture in that throttle range.The primary air(commonly refered to as the Idle screw) adds air to the primary circuit for fine tuning. From 1/4 throttle to 3/4 throttle the fuel is regulated by the jet needle and needle jet. Raising the needle would richen the mixture in that throttle range. After 3/4 throttle, the main jet is the main factor in tuning.
To throw another wrench in the works, most carbs circuits are additive. The fuel that is supplied at idle is also supplied at all other throttle settings.
The circuits add to the mixture that is being supplied by the curcuits at the lower throttle settings.
When jetting, you would usually start with the primary (idle curcuits) and work your way up to jetting at WOT.
Fish
Fish
- DanOz7Five0
26 Feb 2006 10:00
kzrider.com/forum/viewthread.php?tid=18321
Here is a guideline for what other members have found for jetting.
