1979 KZ1000LTD B3
- lrburke
07 Dec 2008 16:06 #251346
by lrburke
1979 KZ1000LTD B3 was created by lrburke
Does anyone out there know how to adjust the accelerator pump rod on a 79 KZ1000 LTD? I just got the carbs back together and that is the last step so I can install them back on the bike. I am a relatively new mechanic on Kaw's. I mostly work on honda's and suzuki's. I don't want to have to buy a manual. Hope someone can help or direct me to a tutorial on the subject. Thanks
- PLUMMEN
- Thank you received: 104
07 Dec 2008 20:02 #251385
by PLUMMEN
Replied by PLUMMEN on topic 1979 KZ1000LTD B3
measure the rod below adjustment nut you want like 10 1/2 to just under 11mm adjust it to that range;)
- lrburke
08 Dec 2008 03:56 #251408
by lrburke
Replied by lrburke on topic 1979 KZ1000LTD B3
Thanks a lot I will give it a shot. Larry
- lrburke
08 Dec 2008 10:20 #251441
by lrburke
Hey there, was that dimension from the end of the rod to the leading edge of the nut or to the lever? The reason I am asking is because when I set it at 10.5 mm to the nut,it seems like the plunger has very little room left to do anything. I set it to 10.5 to the lever and it seemed to be working better. I am just asking. Thanks
- PLUMMEN
08 Dec 2008 20:34 #251538
by PLUMMEN
exposed threads ifi remember right havent done it in years but it sticks in my head for some reason
