Carb difference question
- chelms27
06 Dec 2008 14:53 #251078
by chelms27
1977 KZ1000...16k miles 2nd owner all original except tires, dyna-coil, and a vance and hines 4 to 1 exhaust.
Carb difference question was created by chelms27
I two sets of carbs, the original 26mm's and what I am 99%sure are 28mm's bored out. The two carbs look alot alike but I noticed on the 26's there is only one vacuum line which is blocked off on the #1 carb (one with choke) on the 28's there is one there and on the 3rd carb. Any advice on that? also my 26's have two gas lines one going in between each pair of carbs and the 28's have only 1 gas inlet in the middle of all of the carbs?? Sound ok? do I need a single outlet petcock? Thanks for any comments
- chelms27
06 Dec 2008 18:13 #251136
by chelms27
Replied by chelms27 on topic Carb difference question
Ok the question is what do I need to do to make the 28's center fuel inlet work when I have a double petcock?
- Thank you received: 2098
07 Dec 2008 01:19 #251207
by Patton
Replied by Patton on topic Carb difference question
chelms27 wrote:
Okay to use either petcock outlet and cap off the other unused petcock outlet (a vacuum plug sometimes works just fine).
Good Luck!
Good Luck!
- chelms27
07 Dec 2008 06:26 #251225
by chelms27
ok, I will try that. Thanks
