Mikuni 34mm Flat Slides on 81 KZ750
- CSmith
06 Dec 2008 13:21 #251069
by CSmith
75 Z1, 1075cc, Dyna S Ignition, Mikuni RS 34mm, Inverted Forks & Mono Rear Shock.
76 KZ900 LTD Stock
80 KZ750 Dyna Ignition, Kerker pipe
Mikuni 34mm Flat Slides on 81 KZ750 was created by CSmith
I have an 81 KZ750 with everything stock except the ignition, pipe, and pods. I am looking to put a different set of carbs on. I would like to put on some Mikuni 34mm flat slides. What do you guys think?? Is it possible?? I don't know if they will fit or not.
76 KZ900 LTD Stock
- steell
06 Dec 2008 22:09 #251183
by steell
Replied by steell on topic Mikuni 34mm Flat Slides on 81 KZ750
I think 34mm flat slides would be more than a bit of overkill on a stock 750 motor :woohoo:
34mm CV carbs such as Mikuni BS34's would work good though.
- timebomb33
- Thank you received: 10
06 Dec 2008 22:14 #251185
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Mikuni 34mm Flat Slides on 81 KZ750
like steel said they might be a bit much for that motor stock it would give you lot's of top end but your drivability down low would suffer those carbs were built for high compression high reving 4 valve motors. the 34 cv's would be a much better choice,those carbs came stock on early model gsxr 750's that idled at above 3000 rpm.
- kawsakiman
- Thank you received: 6
07 Dec 2008 20:00 #251384
by kawsakiman
Replied by kawsakiman on topic Mikuni 34mm Flat Slides on 81 KZ750
first off, welcome since this is your first post.
now we need pictures of your bike.
there will be different opinions for your question.
the 750 had 34 cv's from the factory but the flatslides are a MUCH better carb.
it's kinda like putting a 750 cfm holly on a 305 motor.
just soggier then a day old bowl of corn flakes at idle or cruise speeds but runs like hell at top end.
best bet?
i would go with a good set of 26mm carbs instead.
flatslides would be a bit of overkill on a stock internal motor 750.
they are overkill on most stock 900-1000 cc bikes.
ok, we answered your question, now make with the pictures!
best bet?
- kzr750r1
- Thank you received: 9
07 Dec 2008 20:08 - 07 Dec 2008 20:09 #251386
by kzr750r1
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Replied by kzr750r1 on topic Mikuni 34mm Flat Slides on 81 KZ750
What they said. Had a bitch of a time getting it to run clean through the entire range. Never going to be a smooth mix. It's all about WFO...
Have to keep the R's up a bit more than I like around town.
Unless your planning a full Mod Motor now, go for the BS.
Having these carbs are making me think of the bad things I can do to my wallet with the rest of the motor mods needed to take full advantage.
I'm debating putting my BS back on. Go figure.
Last edit: 07 Dec 2008 20:09 by kzr750r1.
- CSmith
07 Dec 2008 20:52 #251393
by CSmith
76 KZ900 LTD Stock
Replied by CSmith on topic Mikuni 34mm Flat Slides on 81 KZ750
I guess all that makes sense. It is my brothers bike and he wants to add more "cool" things to it. I think he is jealous ever since I finished mine up this summer. Thanks for the help guys.
kawasakiman-
I updated my avatar. I guess I forgot to throw a picture in there when I registered.
Are the BS series a round slide carb??
kawasakiman-
76 KZ900 LTD Stock
- steell
07 Dec 2008 21:59 #251398
by steell
Yep, a round slide constant velocity carb, AKA "CV" carbs.
- timebomb33
08 Dec 2008 16:49 #251496
by timebomb33
have you got a better picture of your bike say in the gallery it looks like the stuff id say nice looking hotrod but i left my magnifing glass at home
- CSmith
09 Dec 2008 08:02 #251605
by CSmith
76 KZ900 LTD Stock
I will post a pic or 2 when I get home today.
76 KZ900 LTD Stock
- CSmith
09 Dec 2008 16:41 #251653
by CSmith
76 KZ900 LTD Stock
76 KZ900 LTD Stock
- kawsakiman
09 Dec 2008 19:40 #251683
by kawsakiman
now that is a sweet bike!
- CSmith
09 Dec 2008 21:42 #251711
by CSmith
76 KZ900 LTD Stock
Thanks!
76 KZ900 LTD Stock
