- Thank you received: 235
cleaning idle circuits on the 29 smbores
- trianglelaguna
05 Dec 2008 13:09 #250849
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
cleaning idle circuits on the 29 smbores was created by trianglelaguna
So in a hour or so i'm gonna clean my carbs again(hopefully right this time)"and put a petcock diaphram in."
the whole reason i cleaned em last week (petcock issue)
I have never had problem before doing the basic cleaning in the float bowls untill this last time, and am wondering how to locate my clogged idle circuits "specifically'.
i checked for old threads on this subject before asking you folks ,,,i just want to go forward on the carb thing and get a ride in this weekend and it only runs on choke,wiredgeorge said,and i agree, that my idle circuits are clogged
so today i am retrace and gonna repeat the process.
Remove carbs
remove bowls on a clean bench in order
remove pins from the floats.in order
remove seat needles,in order
clean and spray with carb cleaner all fuel inlet ,vent ,and brass holes.
spray clean carbs out with my compressor
*****Do i need to remove the flat head brass jetts????**** or just blast with cleaner????????????????????????????
then reassemble them....
hope any one can see if i'm missing somthing ...peace craig
Remove carbs
1976 KZ900
2003 ZX12R
2007 FZ1000
- Thank you received: 2098
05 Dec 2008 15:25 #250870
by Patton
Replied by Patton on topic cleaning idle circuits on the 29 smbores
This link points to an earlier thread containing some useful tips about cleaning pilot circuits.
Tips
Haven't yet experimented with boiling carbs in vinegar or lemon juice, but other members report success when doing so.
When cleaning 29's, would suggest NOT removing the jet block.
Good Luck!
Tips
Good Luck!
05 Dec 2008 15:44 - 05 Dec 2008 16:16 #250871
by Patton
Am trusting there's a good exploded view diagram of the 29's on hand for reference.
And thinking the 29's have a small removeable air jet where freshly filtered air for the pilot circuit goes into the small entrance hole on the airbox side of the carb.
This link has a good clear exploded view.
Just go to the site and scroll down.
It also includes a parts lists and parts numbers.
Exploded view of VM29 Mikuni smoothbore carb
Last edit: 05 Dec 2008 16:16 by Patton.
- trianglelaguna
05 Dec 2008 16:24 #250883
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
Replied by trianglelaguna on topic cleaning idle circuits on the 29 smbores
thanks patton that blow up view was great i saved it ....here goes...peace craig
1976 KZ900
2003 ZX12R
2007 FZ1000
- timebomb33
- Thank you received: 10
05 Dec 2008 18:03 #250911
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic cleaning idle circuits on the 29 smbores
spray carb cleaner in the passages and then blow them out with a rubber tipped air gun until they come free.
- trianglelaguna
07 Dec 2008 11:09 #251291
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
cleaned jets and every removable peice in the bowls, air mix screws,passages , reset air mix at 3/8 turn from seated lightly.....copper wire and a dish of carb cleaner..starts on one touch... chokes perfect in 30 seconds and ready..snaps to life in a flash...pulls super hard...no popping..awesome ...THANKS KZR and FOLKS...i got my smoothbores back.....awsome ride this morning..thanks guys...peace craig..p.s z1 enterprises no hassle replacement of my diaphram ---installed ---and leaked 0 gas ,no smell last night in the garrage..thanks rob at z-1
1976 KZ900
2003 ZX12R
2007 FZ1000
- Sandy
- Fly High,Tony
- Thank you received: 13
07 Dec 2008 11:47 #251306
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic cleaning idle circuits on the 29 smbores
Right on Craig!!:woohoo:
1977 KZ1000 A-1
