Stupid question about petcock
- mattsand
04 Dec 2008 08:31 #250671
by mattsand
Stupid question about petcock was created by mattsand
OK, I have a 1980 550 ltd. My stupid question is.... which setting is which for the petcock? There are no markings for on, off, etc.
Feel free to laugh at the total newbie, but I also appreciate any help.
ps- manual is on the way via ebay, but the guy turns out to be gone till Dec 8, so shipping isn't for a while yet, and patience is not one of my virtues.
- PLUMMEN
- Thank you received: 104
04 Dec 2008 08:51 #250675
by PLUMMEN
Replied by PLUMMEN on topic Stupid question about petcock
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo: hell i dont know,but you said to laugh!:laugh: welcome to z-jungle !
- timebomb33
04 Dec 2008 09:34 #250683
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Stupid question about petcock
it has a vacuam operated petcock so the position to the back is the prime position[fuel will flow freely]
- Locozuna
04 Dec 2008 09:52 #250684
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic Stupid question about petcock
There should be PRI (prime), ON (on:huh: ) and RES (reserve). prime is to fill the bowls on the carbs (occasional use). ON is the position it will mostly be in. RES is for when you run out of gas on ON (it should get thee to a gas station). When not running it should be on ON also.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- H2RICK
- Is this a fun bike, or what!!!
04 Dec 2008 10:12 #250687
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Stupid question about petcock
The following procedure is best done out of doors with NO SMOKING and no lights or open flames nearby when performing this check. Make sure you're wearing the usual personal protective gear when handling gasoline in ANY circumstance. Having a suitable fire extinguisher close to hand is also an excellent idea.
If you yourself have never performed this type of procedure before, I strongly recommend that you have this work performed by a licenced motorcycle mechanic.
Are all the ambulance-chasers happy now ???:laugh:
With most vacuum operated petcocks (and I would assume yours is no different) the normal "Run" position is with the lever handle pointing straight down. "Reserve" is usually with the lever handle pointing toward the front of the bike. "Prime" is usually with the lever handle pointing towards the rear of the bike. A quick check can be made by disconnecting the gas line from the petcock outlet and WITH THE ENGINE STOPPED AND KEY TURNED OFF, rotate the petcock lever to the various positions. Fuel should NOT flow out of the petcock in any position except the "Prime" position. Have a small cup handy to catch any flow of gas in any case.
- JMKZHI
- Thank you received: 48
04 Dec 2008 10:35 - 04 Dec 2008 10:36 #250690
by JMKZHI
Replied by JMKZHI on topic ............
Do you have the Owner's Manual? -->> pull-down compartment under seat
Last edit: 04 Dec 2008 10:36 by JMKZHI.
- Thank you received: 2098
04 Dec 2008 12:22 #250696
by Patton
Replied by Patton on topic Stupid question about petcock
Per FSM for 77-79KZ1000's, vac petcock positions are
ON - - - lever handle down (run)
RES - - - lever handle up (reserve)
PRI - - - lever hande to rear (prime)
Sorry don't know whether 80KZ550LTD positions might differ.
When testing for fuel flow in the ON or RES position, a vacuum (suction) must be supplied to the petcock.
When testing for fuel flow in the PRI position, no vacuum is required.
Good Luck!
Good Luck!
- mattsand
04 Dec 2008 22:56 #250782
by mattsand
Replied by mattsand on topic Stupid question about petcock
Thanks for the answers, much appreciated!
