- Thank you received: 235
29 smoothbores running on choke only
- trianglelaguna
01 Dec 2008 19:39 #250259
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
29 smoothbores running on choke only was created by trianglelaguna
Hey folks,
i cleaned my carbs while i was messing with a petcock issue the other day ,,carb cleaner....sprayed out my jets, removed the floats and cleaned my needle floats off & reinstalled them and the floats sprayed out my inlets and put em back on last night i tried to run it ...to many projects...and it wants full choke to even sound close to running good if i give it gas ir boggs if i take off the choke and give it gas it dies...i know ,i know, or once knew. whats wrong but am having a brain stall... i got a great perfomance and a normal manual so tomorrow night i'll re-read it it before tearing into the carbs again ...somthing simple i'm sure ...any help would be cool too,, as i am still rusty but trying to get stuff going ...peace craig
1976 KZ900
2003 ZX12R
2007 FZ1000
- Sandy
- Fly High,Tony
- Thank you received: 13
01 Dec 2008 19:54 #250262
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic 29 smoothbores running on choke only
What did you do with the VENT-LINES?
Did you leave them hanging,or did you happen to connect them from one set of (2) carbs to the other?
1977 KZ1000 A-1
- trianglelaguna
01 Dec 2008 20:17 #250267
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
Replied by trianglelaguna on topic 29 smoothbores running on choke only
i just put some lines on em and ran em up under my tank to frame to seat area. the smoothbores only have two "vents"?one between each inner and outer carbs and none on the bowls...peace
1976 KZ900
2003 ZX12R
2007 FZ1000
- Sandy
- Fly High,Tony
01 Dec 2008 20:25 #250268
by Sandy
1977 KZ1000 A-1
Yes,I realize that.
And the lines are no way getting pinched anywhere?
To what point exactly,did you pull the carbs apart?
1977 KZ1000 A-1
- trianglelaguna
01 Dec 2008 20:32 #250270
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
not pinched,,i only pulled the bowls and the floats and wiped off the seat needles under the float tabbs and sprayed out all the nooks and crannys ,no top work ,no air mixture screws,,,thanks( just making sure i was on the same page on the vents}
1976 KZ900
2003 ZX12R
2007 FZ1000
- Sandy
- Fly High,Tony
01 Dec 2008 20:47 #250271
by Sandy
1977 KZ1000 A-1
I'd pullem again,and get some compressed air in there.
Chances are,you have some grit plugging up one of the choke circuits.
How bad did the bowls look when you pulled them off?
1977 KZ1000 A-1
- trianglelaguna
01 Dec 2008 20:52 #250273
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
grimy but not gritty,i'm gonna thanks for your answers i'm hitting the hay peace and dream wheelies craig
1976 KZ900
2003 ZX12R
2007 FZ1000
- wiredgeorge
02 Dec 2008 05:21 #250331
by wiredgeorge
Replied by wiredgeorge on topic 29 smoothbores running on choke only
The pilot circuits are dirty/obstructed.
- trianglelaguna
02 Dec 2008 07:41 #250350
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
thanks george,
they were on now about 9 months or so since you last advised me on jets and mix screw settings and had lost a little of the clean open snap closed operation i rememberd them having so i cleaned the easy stuff...i must have got somthing in there maybe from a torn or ethanol chewed petcock diaphram.. or blew some dirt in instead of out...my bad...will correct ...peace and as allways thanks...
1976 KZ900
2003 ZX12R
2007 FZ1000
