Z1R with 40's
- Z1Rider
21 Nov 2008 05:59 #248626
by Z1Rider
Z1R with 40's was created by Z1Rider
I just bought back a Z1R that I owned years ago. It's been hacked into a half ass drag bike. Sombody put a nice set of 40mm flats on it with a big header. I have not even tried to start it due to lack of guage cluster, wiring, battery, fuel delivery, ect. There are no apparent engine mods other that dyna ignition and a two step box. Along with the bike I got 3 boxes of parts, one has what appears to be the original 28mm carbs and manifolds. Is it possible to make 40's work on a stock motor with small jets or does it make sense to get the crusty old 28's rebuilt? I plan on riding this one.
- wiredgeorge
21 Nov 2008 06:19 #248632
by wiredgeorge
Replied by wiredgeorge on topic Z1R with 40's
The 40s have a huge venturi, ensuring air flow is real slow and won't work on a stock 1015cc very well... they will start and idle but when you crank the throttle open rapidly, will bogggggggg badly. Too much air and you won't be able to tune out the bog. The stock 28s are far more suitable for a stock bike.
- Sandy
- Fly High,Tony
- Thank you received: 13
21 Nov 2008 06:53 #248641
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Z1R with 40's
WAY too much carb for a stock motor.
Have a look at this,for example...
kzrider.com/index.php?option=com_kunena&...ew&catid=3&id=247792
1977 KZ1000 A-1
- PLUMMEN
- Thank you received: 104
21 Nov 2008 07:16 #248647
by PLUMMEN
Replied by PLUMMEN on topic Z1R with 40's
the 1st thing i removed from my 1327 was the 38 flatslides!:laugh:
- donthekawguy
- Thank you received: 8
22 Nov 2008 00:00 #248757
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic Z1R with 40's
List the 40's on ebay under dragbike. You might make enough off of them to pick up a set of 29's.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
