Still have rpm hang between shifts
- sbulla
- 1980 KZ1000 LTD
23 Nov 2008 13:01 #249013
by sbulla
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
Replied by sbulla on topic Still have rpm hang between shifts
Patton wrote:
Dude!, I think you nailed it!
I cleaned the advancer up as there was some old looking thick grease on it, put some lighter lube in it's place, worked it in a few times, reinstalled the carbs, fired it up and,....NO HANG!
I, also applied some sealant to the new carb holders I had installed previously but, I really don't think there was an issue with them.
Anyway, took it for a ride today as the temps got up to 50 and it's running good!
Thanks a ton,
Sonny
Even with perfect carbs, if fitted with a mechanical advancer for ignition timing (the spring loaded version with weights spread by centrifugal force), sometimes the advancer hangs or sticks momentarily in the advanced position, which may cause delay in returning to lower rpm. In such case, cleaning and lubing the advancer may resolve the matter.
Thanks a ton,
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- GaryZ
22 Jan 2009 09:36 #259360
by GaryZ
GaryZ
Oklahoma City, OK
'80 KZ1000-A4 / '85 Yam. Venture Royale / '99 ZX11D
Replied by GaryZ on topic Still have rpm hang between shifts
I have been fighting the same RPM "hang" for a very long time. Rebuilt the carbs, did a mechanical sync on the bench, an on-the-bike sync and my KZ1000-A4 would not idle below 1500rpm no matter what I tried. Thanks to this thread I lubed the mechanical advance, re-synch'd and the problems are fixed. Thanks!
I also tried out my new ColorTune and learned a very important lesson on setting air screws for a stock bike like mine. The factory setting of 1 1/8 inch is dead on. My KZ has not run this good in years.
GaryZ
Oklahoma City, OK
