- Thank you received: 16
Need alum plug for 82 KZ1000 34mm CV carb bad
- mtkawboy
18 Nov 2008 14:44 #248150
by mtkawboy
Need alum plug for 82 KZ1000 34mm CV carb bad was created by mtkawboy
I lost the aluminum plug out of 1 80 GS1100 Suzuki 34mm CV carb that goes into the carb body opposite the float pivots, It has a flat rubber o-ring that goes over it and the float bowl seals it off. Desperate, name your price, need it bad. Will keep looking for the lost one. Dealer shows no replacement. This is the same carb and part that goes into later model 82 up KZ1000, 1100s & GPZ750s. Hate to ask on here but Im desperate and have a lot of Kaws in the fleet
- OnkelB
- Thank you received: 80
18 Nov 2008 15:17 #248154
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic Need alum plug for 82 KZ1000 34mm CV carb bad
If you're referring to the plug that fits over the pilot jet I'm pretty sure that Jeff at Z1E has them or can find them for you, try giving him a hollar. If I recall correctly there are two different type plugs used on the BS34s, one is aluminum, the other is rubber - I believe either type can be used.
- mtkawboy
18 Nov 2008 16:27 - 18 Nov 2008 17:10 #248167
by mtkawboy
Replied by mtkawboy on topic Need alum plug for 82 KZ1000 34mm CV carb bad
No, I have the rubber plug for the pilot jet. This is an aluminum plug about 3/8 around with a step on it that drops in a hole in the carb body then a flat o-ring goes over it and the float bowl covers it and seals it. This is for a Cv carb
Last edit: 18 Nov 2008 17:10 by mtkawboy. Reason: changed size of plug after measuring
- Thank you received: 2098
18 Nov 2008 20:28 #248229
by Patton
Replied by Patton on topic Need alum plug for 82 KZ1000 34mm CV carb bad
If a grossly wild guess may be forgiven, would it be possible to mash a lead fishing line weight into the hole?
- wiredgeorge
19 Nov 2008 06:26 #248300
by wiredgeorge
Replied by wiredgeorge on topic Need alum plug for 82 KZ1000 34mm CV carb bad
The purpose of the plug isn't clear. Some of the other versions of the BS34 have a bit that fits in that hole. On the Suz BS34, the hole must be plugged otherwise it is a massive air leak in the venturi. They are glued in at the factory and are a part of the carb body and don't carry a separate part number. Put a piece of tape over the hole and fill with JB Weld or get another set of BS34s and put a punch on one of the donor plugs from the inside and give it a tap. It will fall out. You can then use it in the carb body you need it for.
- mtkawboy
19 Nov 2008 08:11 #248317
by mtkawboy
A guy is supposed to send me one from another forum. Really appreciate the help anyway George & the rest of you. I have some 81 Yamaha XS650 carbs that look like the same plug I was going to try to remove too. Thanks for all the help guys, great forum, great people. Ive helped people with parts in the past & what goes around, comes around
- gane
19 Nov 2008 18:16 #248392
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Need alum plug for 82 KZ1000 34mm CV carb bad
M, am familiar w/ your' plug, different series, use different dia/depths stepped & plain, some even use protrusions from float bowl to seal, if your' incoming bit doesn't work out, repost w/size/s and I'll search my bits.Luck G
