- Thank you received: 5
Wher are my air fuel mixture screws or caps?
- cnyl
18 Nov 2008 12:44 #248144
by cnyl
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
Wher are my air fuel mixture screws or caps? was created by cnyl
Hi guys!
I'm in the process of cleaning a set of MIKUNI carbs from my
82 KZ1000 M2 CSR. I don't see the air fuel mixture screws or caps to drill out. Am I missing something? I ordered a service manual but I don't have it yet. Any help would be appreciated.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
- cnyl
18 Nov 2008 15:04 #248153
by cnyl
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
Replied by cnyl on topic Wher are my air fuel mixture screws or caps?
Well.... After cleaning all the muck off I found them. They're on top. Just got finished boiling them in lemon juice and they look great! That lemon juice works wonders.lol
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
- wiredgeorge
19 Nov 2008 06:28 #248301
by wiredgeorge
Replied by wiredgeorge on topic Wher are my air fuel mixture screws or caps?
They are plugged with the pilot mixture screw very close to the plug. If you drill the plugs, you will likely nick the tops of the screws, so be careful. If you remove the screws, replace the orings which are REAL OLD and likely not working very effectively. When you replace the screws, turn them in till very lightly seated and then out about 1 3/4 turns.
