HOW LIMITED ARE THE 29MM SMOOTHBORES?
- madkawltd90076
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- PLUMMEN
- Thank you received: 104
- timebomb33
- racer54
- Thank you received: 114
- timebomb33
- trippivot
- Thank you received: 3
the C.F.M. on a stock KZ head is 65 approx. the "little" 35mm intake valve is the biggest factor to what is limiting your power making capacity. more cam lift is a helping factor.
Increasing total C.F.M. thru the head.
Putting efforts towards lower cam lift flow numbers.
Higher compression level aka combustion efficiency are going to get you to the next level
the optimal carb diameter is at a ratio of 0.85 diameter of the intake valve diameter. and the tuned intake length is determined to what R.P.M. you want to peak at.
these carbs will make more power than the combination of parts you already have, assuming you have stock valve diameters and un altered combustion chamber volumes.
madkawltd90076 wrote:
I was wondering what kind of power numbers can be attained with the use of these carbs on a 1075 engine with 425 cams. Im sure that ideally a 34mm flatslide would be the way to go but if the 29 smoothbores wont sacrifice that much power I would prefer to use them.
- timebomb33
- trippivot
I have a thing for performance... tuned perfection.
trig. and some sweat == big torque and power out of small engines.
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- timebomb33
- madkaw1200
