bogging down
- jhinely27
14 Nov 2008 22:15 #247487
by jhinely27
bogging down was created by jhinely27
I have a 1976 kz900 with stock 26mm carbs with a #115 main and a #15 pilot. It has either the 1015cc or 1035cc kit in it. It bogs down when i first takeoff from a stop(just in neutral it revs up great but as soon as its is under a load it bogs). what jets should be used i was going to try a 17.5 pilot jet and see what it is like.
- bountyhunter
- Thank you received: 337
15 Nov 2008 13:03 #247568
by bountyhunter
Replied by bountyhunter on topic bogging down
If it bogs as you roll on the throttle from idle I would check the fuel levels in the carbs and maybe adjust needle height.
- timebomb33
- Thank you received: 10
15 Nov 2008 13:53 #247577
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic bogging down
it sounds to me that your needle heights are to rich try the middle position also look at your gearing it might be to high how long have you ridden the bike and have you done anything different to it. let's start with that first give us a list of what is on this bike [air filters ,pipe, cam's and whatever else you can think of or find out. it kind of sounds like you must have just got this bike.
- jhinely27
15 Nov 2008 14:51 #247589
by jhinely27
Replied by jhinely27 on topic bogging down
had it a couple months actually(just got tired of messing with it). ive tried different needle heights, adjusting the mixture screw, setting float levels, cleaning the jets . it has individual k&n's(just cleaned and oiled), a vance & hines 4 into 1(unmolested that has the baffle), stock cams (so i was told), dyna coils and ngk sparkplugs and caps. I always run 93 octane gas and use 10w 40 oil
- timebomb33
15 Nov 2008 15:54 #247596
by timebomb33
it sounds like your main jets are close and your stock pilots would work does it idle alright and return to idle alright by itself,one other question does it accelerate well in the other gears.
- wiredgeorge
19 Nov 2008 06:39 #248303
by wiredgeorge
Replied by wiredgeorge on topic bogging down
The main jet is stock size for a 76 KZ900. The stock pilot jet should be a #17.5. Do you have the stock airbox on this bike?
- Thank you received: 2098
19 Nov 2008 15:27 #248375
by Patton
Replied by Patton on topic bogging down
If not already done, would assure strong spark, correct ignition timing and advancer function, and check/adjust valve clearances and floatbowl fuel level. All before addressing carbs. Because even perfect carbs won't compensate for failures in the non-carb components.
Good Luck!
Good Luck!
