Petcock leaking but can't tell from where???
- ghunt81
01 Nov 2008 22:43 #245094
by ghunt81
1978 Kawasaki KZ750 Twin- Coil mod, Dyna coil, 7mm copper core wires
Petcock leaking but can't tell from where??? was created by ghunt81
I have noticed lately that my fuel petcock leaks, but only when it is open (this is on a '78 KZ750 Twin).
Gas will drip off the bottom of it, I have looked at it very closely and I really can't seem to determine exactly WHERE the fuel is coming out...it is wet from the bottom of the petcock lever itself to the bottom of the drain plug (or whatever it's called) on the bottom of the petcock.
Is there an O-ring kit for this petcock, should I just go through and replace any/all gaskets and O-rings?
- MFolks
- Thank you received: 540
01 Nov 2008 23:05 #245096
by MFolks
Replied by MFolks on topic Petcock leaking but can't tell from where???
Fuel especially now with the alcohol added will deterioate the O rings and gaskets of the petcock on the gas tank.
I'd replace all of them because the ones you don't replace now will be the ones that leak in the future!
- timebomb33
- Thank you received: 10
01 Nov 2008 23:34 #245105
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Petcock leaking but can't tell from where???
k&l supply makes pet-cock kits for a lot of older bikes i think z1-enterprises sell them. they are really easy to install if you don't have any luck with that try pingel they build hi flow petcocks that work very well i have 4 of them on different bikes.
- Thank you received: 2098
02 Nov 2008 02:02 - 02 Nov 2008 02:20 #245110
by Patton
Replied by Patton on topic Petcock leaking but can't tell from where???
Would check tightness of the sediment bowl and integrity of its o-ring seal.
Would also assure integrity of o-ring seal where petcock attaches to tank, this being the o-ring between the petcock and the male-threads from tank. The factory o-ring is flat on both sides, however, a common round style o-ring will suffice provided it's the correct size. The o-ring fits in a groove inside the large nut which squeezes the petcock against the tank fitting, and the o-ring is supposed to seal against leakage at this juncture. A loose nut or failed o-ring may allow leakage over exterior of petcock.
Would also disassemble petcock and check for damaged (scoured) interface between plastic valve and inside surface where it twists back and forth. I suspect grit from inside the fuel tank may cause such scouring.
And also check the o-ring around the lever.
Replacing the plastic valve might help (if lucky enough to find that item ). And my efforts toward restoring an internally scoured interface have woefully failed .
Good Luck!
Good Luck!
Last edit: 02 Nov 2008 02:20 by Patton.
- Biquetoast
- King Jeremy The Wicked
03 Nov 2008 18:46 #245432
by Biquetoast
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
Replied by Biquetoast on topic Petcock leaking but can't tell from where???
ghunt81 wrote:
You can get a "petcock rebuild kit" for this petcock from ebay or places like z1enterprises.com. It consists of about 3 or 4 o-rings. It will solve your problem.
kz750twins.com
- cubajean10
05 Nov 2008 08:24 #245691
by cubajean10
Replied by cubajean10 on topic Petcock leaking but can't tell from where???
i had a similar problem, the last owner told me it was broken so i bought a replacement here
ebay petcock
i sent this message to the seller but no reply can someone help me?
I HAVE A QUESTION ABOUT HOW TO SET THIS THING UP, THE LAST PIECE I HAD WAS ALMOST EXACTLY THE SAME AS THE ONE YOU SENT ME. THE DIFERENCE IS THAT MINE HAD ONLY ONE OF THE REFERED OUTLETS {THE LEFT ONE I THINK }(" look it does have the two outlets that you need") AND REFERING TO THE PICTURE YOU HAD IN THE AUCTION THE WHOLE ABOVE THE OUTLET WAS OPEN NOT CLOSED.
SO THE TUBES I HAD CONECTED WERE ONE TO THE SIDE HOLE AND ONE TO THE OUTLET, AND I'M NOT SURE HOW IT GOES ON YOUR PIECE ONE TO EACH OUTLET NOT MATTER WHAT?
ebay petcock
- RonKZ650
- Thank you received: 240
05 Nov 2008 10:10 #245716
by RonKZ650
Replied by RonKZ650 on topic Petcock leaking but can't tell from where???
I'm not 100% on your question, but if you have 2 fuel lines going to your carburetors, one going to a T fitting between the 1-2 carbs, the other to a T between the 3-4 carbs it doesn't matter which fuel line goes to which outlet on the petcock on the manual petcock. This was the way it was done on the Z1,KZ900, KZ1000 up till 1978 and the 1000LTD through 1980. If you only have a single fuel inlet on your carbs between 3-4 carbs like used on the 79-80 KZ1000A-E, KZ650 ect, then you need to run that to a T fitting then two short pieces of hose to each outlet on the petcock.
