rpm related problem not throttle position..
- School Teacher
29 Oct 2008 22:36 #244581
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
rpm related problem not throttle position.. was created by School Teacher
ok i have a set of keihn 34mm cv carbs on my 1000g that has a 1075 kit
ran fine when stock
now at 4800rpm flat spot till i hit about 6000 then to the moon i go
still there if i throttle up slow and try to cruise through it or if i am hole shotting wide open(when i am on it i just get through the rpm range quicker)
i have stock jets accept for the mains which are 136
is it something other than my carbs?
ran fine when stock
1980 kz1000G1
- bountyhunter
- Thank you received: 337
29 Oct 2008 22:51 #244585
by bountyhunter
Replied by bountyhunter on topic rpm related problem not throttle position..
School Teacher wrote:
I would guess that it's carbs/headers/airbox characteristics assuming the spark advance is working correctly.
- timebomb33
- Thank you received: 10
30 Oct 2008 06:47 #244612
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic rpm related problem not throttle position..
where this is happening is in your mid -range so that is were the needle circuit comes in to play try to richen that up by richen it up i mean lower your clip position on the needle. don't go 1 clip at a time ether make a drastic change and see if that improves the situation. if you go 1 clip at time it will take for ever to find out if what your doing is right.
- School Teacher
30 Oct 2008 10:40 #244653
by School Teacher
1980 kz1000G1
Replied by School Teacher on topic rpm related problem not throttle position..
i Will give that a try and report
1980 kz1000G1
- wiredgeorge
30 Oct 2008 11:56 #244665
by wiredgeorge
Replied by wiredgeorge on topic rpm related problem not throttle position..
I suggest when you hit the flat spot, to pull up on your choke lever. The bike will run either better or worse. If it runs better, you are flat from leanness and if worse, you are rich. This will give you a better indication of how to reclip your jet needle. Also, the size of the main jet will affect the mid-range as it is metering the gas that passes through the needle jet/net needle.
- School Teacher
31 Oct 2008 02:53 #244782
by School Teacher
1980 kz1000G1
great advice thanks will do tomorrow
1980 kz1000G1
