Carb rebuilding
- dman3998
I am rebuilding the bike from the frame up and have enough to do with out doing the carbs too. not to mention would be good to have someone that knows what they are doing fix them up.
dman
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- bountyhunter
- Thank you received: 337
- MFolks
- Thank you received: 540
- SPRTYM
- kano
- Not Another Bloody Limey!
- keith1
- Thank you received: 2
- dman3998
thanks
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- dman3998
I have the same problem and the same question. Also, my bike has been sitting in a shed since 1997. Besides the carbs are there any other reconmendations before I try to fire her up? This is my first bike and I am a little lost. By the way she is a 1978 KZ1000.
not sure specifically on the 1000, I am new to the kz scene myself, but on other bikes I always change the oil and filter. no sense sending any "stuff" that has settled in the case circulating around. I also make sure the gas tank is really clean and put in an inline filter, you can suck in a ton of rust and sediment. if It was put away with any water in the brake fluid thers is a good chance the pistons and master cylinders have some pitting and corrosion in them. ie major brakes overhaul. and any appropriate regular maintenance item recommended for the mileage plus up to the next one or two because of age.
Dman
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
