K&L Fuel petcock repair kit
- Tommotbird
22 Oct 2008 10:55 #243233
by Tommotbird
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
K&L Fuel petcock repair kit was created by Tommotbird
Just bought a new petcock repair kit for my KZ1100, I notice that in the packet there are two clear plastic washers. Don't remember seeing any when I removed and dissembled the petcock. Would I be right in assuming that they fit on the bolts that attach the petcock to the gas tank?
Tommo
Tommo
Triumph Legend
Lambretta SX150
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
- Bluemeanie
- Thank you received: 14
22 Oct 2008 20:17 - 22 Oct 2008 20:18 #243310
by Bluemeanie
Replied by Bluemeanie on topic K&L Fuel petcock repair kit
Not familier with 1100's but my 650 petcock uses an oblong O ring to seal against tank. Sounds like you are correct in that the plastic washers are for sealing. Check out
Kawasaki.com
and see if they show the washers on your petcock.
Last edit: 22 Oct 2008 20:18 by Bluemeanie.
- Zthou1977
23 Oct 2008 05:19 #243354
by Zthou1977
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
Replied by Zthou1977 on topic K&L Fuel petcock repair kit
IIRC this petcock is fastened to the tank using two bolts. If so, the washers are for the bolts, between bolt-heads and the flange of the petcock. They stop any leaking along the bolts, and will also prevent the bolts from backing out due to vibrations.
- timebomb33
- Thank you received: 10
24 Oct 2008 22:38 #243674
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic K&L Fuel petcock repair kit
you are correct sir ,put lots of those kit's in over the years.
