- Thank you received: 5
cleaning fuel injectors?
- IowaKZ
- '80 G1 Classic
14 Oct 2008 20:08 #241839
by IowaKZ
1980 G1 Classic
Bettendorf, Iowa
cleaning fuel injectors? was created by IowaKZ
hello all again. I am going to be working on my valve seals and maybe some other things as well. While I have my bike apart, I will want to take a look at my fuel injectors. Is there any way to clean these while they are off the engine or do you clean them by running injector cleaner through the fuel?
Forgot to mention, I have the kz1000 G1 with the original efi.
thanks.
thanks.
1980 G1 Classic
Bettendorf, Iowa
- MFolks
- Thank you received: 540
14 Oct 2008 20:17 #241841
by MFolks
Replied by MFolks on topic cleaning fuel injectors?
I'd try a can of STP injector cleaner in the gas. I use the same stuff in my 99 Camry and it seems to keep the injectors happy. Also some Marvel Mystery oil or Seafoam gas additive should keep things clean.
www.witchhunter.com is a fuel injector repair service if you think yours need servicing.
- gnfreak
15 Oct 2008 20:57 #242030
by gnfreak
Normal, IL
1980 KZ1000-G1 Classic - Sold
Replied by gnfreak on topic cleaning fuel injectors?
i was wondering the same thing on my classic. i know there're places that clean and flow injectors for my buick grand national. wouldnt these same places be able to do the same for the kawasaki? it would be nice to have actual numbers instead of just running cleaner thru them and guessing if they are all flowing the same. i'll try contacting some of these places and get back to ya iowaKZ.
Normal, IL
- gnfreak
15 Oct 2008 21:08 - 15 Oct 2008 21:41 #242031
by gnfreak
Normal, IL
mfolks, thanks for the link to witchhunter.com. i sent an email to try to get some info.
just got a quick reply from them. they can indeed service these injectors. looks like something for the winter to-do list
Normal, IL
Last edit: 15 Oct 2008 21:41 by gnfreak. Reason: more info
