Jet change after Using POD filters
- svcc2006
15 Feb 2006 17:53
I am converting from an airbox to pod air filters so I'll need bigger gas jets on my KZ 400. Can anyone tell me the exact jet needed?
- OKC_Kent
Re: Jet change after Using POD filters
15 Feb 2006 18:27
Probably not without some more information. Do you know what jet is in there now? And then there's more.
Cashion, OK
78 KZ650 B2 85,000+ miles
- wiredgeorge
16 Feb 2006 05:31
Put your year/model in your signature (and location as well) and you will get more specific help. You need to bump both the secondary main jets and main jets if you run pods else you will have flat spots; especially if you are using a non-stock exhaust system or have removed the baffles in your exhaust. You might want to mention what your current jetting and exhuast set up are for more specific answers as Kent mentioned!
- BRGMGBGT
16 Feb 2006 21:01
Also where you live, altitude?
oops, Wiredgeorge already got that one.
Post edited by: BRGMGBGT, at: 2006/02/17 00:04
