- Thank you received: 1
what to do
- quader98
10 Oct 2008 17:30 #241170
by quader98
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
what to do was created by quader98
im gonna be taking all the bodywork off the bike for the winter and having it all done and i was wondering do i just drain the carbs or what?
82 GPZ 750 R1
- Thank you received: 2098
10 Oct 2008 18:04 - 10 Oct 2008 18:08 #241171
by Patton
Replied by Patton on topic what to do
quader98 wrote:
Yes -- drain the floatbowls.
If tank is staying with the bike, would also consider adding a shot of fuel stablizer and topping it off. If tank is drained instead, would swish some light oil around inside to inhibit rust.
Would air tires up to max psi (per tire mfgr spec.)
Change oil and filter.
Plus a drop of oil on everything that moves.
Remove battery, check and add distilled water if necessary, and place on tender.
If possible, keep bike inside closed garage, and cover it with something breathable (a bed sheet is okay) to keep the dust off. An outside open carport, porch or screened room, would call for a professional cover.
Good Luck!
Good Luck!
Last edit: 10 Oct 2008 18:08 by Patton.
- quader98
10 Oct 2008 18:35 #241177
by quader98
82 GPZ 750 R1
Replied by quader98 on topic what to do
thank you
82 GPZ 750 R1
