Some stock carb questions.
- nfswift
15 Feb 2006 09:15
Most KZs run the stock VM24SS slides but the CSRs came stock with BS32 CV carbs...
24mm vs 32mm is a fairly big difference, and I am aware that CV carbs need the bigger diameter to function properly but could anyone breifly sum up the differences in the behavior and performance between these carbs?
I am just curious, I landed a bonus set of 32mm slides when I got my bike that are in questionable condition, these are a bit big for the 650 no? Hopefully the weather clears so I can get riding soon and experience this stuff for myself.
Cheers.
Cheers.
- wiredgeorge
Re: Some stock carb questions.
15 Feb 2006 11:19
I test hundreds of sets of carburetors every year and both the VM24 and BS32 are among my favorites. Both tune easily and offer good low-end power and economy. The BS32 probably offers better top end potential as it can flow more air/fuel than a VM24 but I think you would need a larger displacement bike (like my test bikes) to notice.
- nfswift
15 Feb 2006 13:28
Ahh, thanks WG, there is no better place to find sounder carb advice around here than you.
I assumed the carbs would have similar characteristics (after all, why would Kawasaki make a drastic difference between two of the same model just based on carbs?), but I am pleased to hear I might have a LITTLE top end on the stock 650 slides though!
It's also a boon that they are easy to set up because I am a novice about all this still (despite how much I've learned hanging about here or actually wrenching myself).
I should find out exactly what model those 32mm slides are and if they are of any interest
Thanks again WG. Maybe someday I'll be up for a 900, but not for now
