Converting KZ400 Carb to run KZ305
- SimpleCJ
05 Oct 2008 09:21 - 05 Oct 2008 10:55 #240244
by SimpleCJ
Converting KZ400 Carb to run KZ305 was created by SimpleCJ
I found a reasonably priced carb set for the KZ400 (94) that I'm thinking would be a good replacement for my 1981 KZ305.
What modifications will be needed to make this work?
Last edit: 05 Oct 2008 10:55 by SimpleCJ.
- SimpleCJ
05 Oct 2008 10:52 - 05 Oct 2008 10:55 #240249
by SimpleCJ
Replied by SimpleCJ on topic Converting KZ400 Carb to run KZ305
Correction, the carb I'm looking at is for a 1979 KZ400... maybe that's too old to be a good swap? I would most likely have the same issue with bad or hard to find replacement parts...
I guess the main question is would I need to replace the jets??
Also, does anyone know if the boots from the 305 will fit the 400 carb?
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
05 Oct 2008 20:32 #240320
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic Converting KZ400 Carb to run KZ305
I think the major problem you are going to run into is the carb spacing is different on these two bikes. The 305 shares more in common with the Z 250 that was sold in Europe and Asia (we never got that bike here in the states) than it does with the KZ 400. I think you might do better to try and check the carb set from a 250 Ninja, those bikes are pretty plentiful. Check with a local bike salvage yard to see if they might have a set you can compare to your carbs.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- SimpleCJ
05 Oct 2008 23:16 #240333
by SimpleCJ
Thanks for the suggestion. Tonight I rigged up the carbs for adjusting the fuel service level. As I had suspected the side I had modified with a new seat and valve-pin wasn't letting any gas in. I fiddled with both floats for about an hour and finally got them both filling to a few mm below the top of the bowls. Now I gotta get my replacement coils (used 1972 Yamaha 250 DS7 coils) and get the bike itself over to my house so I can see if the carbs are set right.
It ran ok before but would flood if you let it sit (that's why I changed the seat/pin). Hopefully the jets and everything is ok and I can just put it together and have it running again.
Of course the coils are a whole other story. It WAS running on universal automotive coils like you might put in a car or something. If the Yamaha coils don't work I've found some nice universal motorcycle coils on JC Whitney for about $25 each.
