2 petcocks?
- Pwallace30
02 Oct 2008 15:04 #239842
by Pwallace30
2 petcocks? was created by Pwallace30
Heres a dumb question, is there suppose to be 2 petcocks on my 1978 KZ650SR? because I have 2 identical openings on the bottom of my tank but there is only one petcock, thanks.
- RonKZ650
- Thank you received: 240
02 Oct 2008 16:13 #239847
by RonKZ650
Replied by RonKZ650 on topic 2 petcocks?
You only have one petcock. Of course each petcock has 3 holes, 2 for the mounting bolts, one large oval one between them. It would be really difficult to add a second petcock if you wanted too. I need pictures.
- Pwallace30
02 Oct 2008 16:57 #239854
by Pwallace30
Replied by Pwallace30 on topic 2 petcocks?
Sorry no pictures, but my tank has a total of six holes on the bottom. The extra 3 holes look like there was a petcock there before, because the holes are the exact same as the wholes for the petcock that is there
- Pwallace30
03 Oct 2008 04:17 #239907
by Pwallace30
Someone has to know what im talking about, anyone?
- Thank you received: 2098
03 Oct 2008 04:31 - 03 Oct 2008 04:41 #239909
by Patton
Replied by Patton on topic 2 petcocks?
Fiberglass tank??
dual petcocks
P.S. Guessing perhaps some competition riders may fit dual petcocks to avoid fuel starvation in event one of them clogs for whatever reason. So what about triple petcocks and be really sure. :woohoo:
dual petcocks
Last edit: 03 Oct 2008 04:41 by Patton.
- KZ550NEWBIE
03 Oct 2008 04:45 #239911
by KZ550NEWBIE
Replied by KZ550NEWBIE on topic 2 petcocks?
I'm new two the motorcycle world but I'm trying to learn. If I understand you correctly you have two sets of hole on the bottom of the tank one on the right and one on the left. If thats correct I would say ones for the pet cock and one is for your fuel sensor. I hope that helps.
- Locozuna
03 Oct 2008 05:35 #239916
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic 2 petcocks?
NEWBIE has it correct. One is for the petcock and the other set of holes are for the fuel sensor. You have or had a fuel gauge/light on that puppy.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- wiredgeorge
03 Oct 2008 05:56 #239919
by wiredgeorge
Replied by wiredgeorge on topic 2 petcocks?
Not sure that the NEWBIE fella is right. The fuel sensor pickup is usually more in the middle of the tank and on the bottom and the holes will be much farther apart. The hole will be round and about 3" as memory serves because there will be a float that has to go in the tank. There would be a small flange welded to the bottom of the tank because there is normally a rubber cover that goes over the place where the fuel sensor pickup goes and some soldered lugs for wires. The rubber piece will also have a drain hose fitting for reasons that are not readily obvious to me.
- SLEEPER650
03 Oct 2008 06:05 #239923
by SLEEPER650
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
Replied by SLEEPER650 on topic 2 petcocks?
newbie's right the one on the left is for the petcock and the one on the right is for the fuel sensor. both holes are oval in shape. i think george is confusing the (sr) with the (j model).your bike should have a light that says fuel on your tach.
78 650sr my baby
82 kz1100
- KZ550NEWBIE
03 Oct 2008 06:20 - 03 Oct 2008 06:20 #239927
by KZ550NEWBIE
I just know by my bike that I'm learning on. That the petcock or fuel tap is on the left side and the fuel sensor is on the right side. Just check a website that has OEM parts the diagram will show you. The holes look alike.
Last edit: 03 Oct 2008 06:20 by KZ550NEWBIE.
- drmadd95
03 Oct 2008 11:19 #239954
by drmadd95
1979 KZ650 B (Main Ride)
1978 KZ650 D1 (sold)
1982 KZ750 (parts bike)
Replied by drmadd95 on topic 2 petcocks?
On my 78 SR the fuel sensor is on the right side of the tank.
- PLUMMEN
- Thank you received: 104
03 Oct 2008 12:41 #239960
by PLUMMEN
Replied by PLUMMEN on topic 2 petcocks?
im not even gonna touch this one,but if i did!ah forget it!:blush: :laugh:
