Engine Forum
Engine forum is a tech forum for "Engine" topics.
Dr. Suzuki (or how I learned to stop worrying and love the petcock)
  • JMKZHI
  • JMKZHI's Avatar
Re: .
26 Oct 2006 06:40 - 03 Dec 2008 16:45
#87465
del
Last edit: 03 Dec 2008 16:45 by JMKZHI.
  • Skyman
  • Skyman's Avatar
Re: Dr. Suzuki (or how I learned to stop worrying and love the petcock)
10 Jun 2007 20:39
#148160
I want to report that I have sucessfully mounted this same Suzuki petock onto my KZ1000.
Details: I have a '78 KZ1000 B2. I picked up a larger tank on Ebay. Best I can tell, the tank is from a '78 KZ1000 A2 (has the bolt-on vacuum petcock). Needless to say, the original petcock leaked. I like the set-and-forget vacuum taps (when they don't leak). So I didn't want to convert to a manual tap.
The refurb kits for this petcock were $50+, and there's no guarantee it wouldn't still leak.
So I bought a Suzuki petcock from Z1 Enterprises. They have two models available on their website--one is $39 and the other is about $45. I asked Jeff what the difference was, and he said "price". :whistle: Other than that, he sees no difference. So get the cheaper one.
When it arrived, I removed the back plate and rotated it 180* so the vacuum nipple faces forward. The fuel nipple faces to the rear, and cannot be changed. As has been discussed earlier in this thread, the rear-facing fuel nipple makes a tight fit with the frame. So rather than bending the fuel hose down and risking a kink, I routed the hose straight back underneath the seat pan, and gave it a nice big arc back under the tank, through a gap in the frame, and into the carb area.
I used a brass tee fitting to route the fuel to the two fuel inputs on the carbs. I don't know if it was necessary, but I tried to keep the lines coming off the tee level so that the fuel would flow equally to both sides. I also used a single button filter to keep the fuel clean.
Here are the pics:
West Linn, OR
  • JR
  • JR's Avatar
11 Jun 2007 20:36
#148539
Cool !.............but will the seat closing down pinch the fuel line ?
  • Skyman
  • Skyman's Avatar
22 Jun 2007 10:40
#151778
Nope. There is enough space there that it does not get pinched. :pinch:
West Linn, OR
