Dr. Suzuki (or how I learned to stop worrying and love the petcock)
- N0NB
- Blue handles better
Re: Dr. Suzuki (or how I learned to stop worrying and love the petcock)
13 Mar 2006 19:26
giftofthegods77 wrote:
If it's the one that goes over the airbox and lays along the frame and ends there, it is the vent tube for carbs 1 & 2. 3 & 4 should have a similar one on the right side. The vent tube keeps the carb bowls at atmospheric pressure which forces the fuel up through the jet and into the venturi. Don't cap them off!!
The overflows are the ones that come out of the bottom of the bowls and go over the backside of the transmission and hang down in front of the rear tire.
- Nate >>
That nasty looking yellow line is an overflow hose (I think).
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- giftofthegods77
14 Mar 2006 09:31
- Nate >>[/quote]
Ah,ha!Thanks!
Chet,
Yeah, I switched the vacuum tube to the other side. I too had to go buy some new line for the vacuum line b/c the original line was too short. Overall, a really easy, relatively cheap fix for such a stupid problem.
Thanks again for being the one to step up and try it out first!
- Nate >>[/quote]
Ah,ha!Thanks!
Chet,
- MadMac74
30 Mar 2006 19:29
Hey you guys, great job sourcing this fix, Mine is clearing customs as I type, thanks ,I'll chat later when its installed.
MAC
MAC
'78 KZ650 C2,810 conversion,stock kz 750 cams,with a Blueprinted Head both from a '81 KZ 750. BS 34 Mikunis, Mac /Kerker 4 into 1 with custom 2" comp baffle. 3 rd owner
'02 ZRX1200R, 3rd owner
'83 XR200R, 3 rd owner
'84 V65 Sabre 3 rd owner
- Jeff.Saunders
31 Mar 2006 06:36
It's good to see the pictures to validate them fitting. It does fit fairly well. We've tried to search out some alternative ones - the Suzuki petocks are the only bolt-on 44mm vacuum style we've been able to find (that will fit most bikes).
- tnewkirk
01 Apr 2006 07:45
Thanks for the info.This has been a stumbling block to getting my 78650sr running.As soon as i saw the pics i got a smile on my face.Thanks
- MadMac74
Re: Great repair, good sourcing
06 Apr 2006 17:39
Just like I figured , It works fine Thanks guys! Hey Jeff , one week and one day out to BC, can't beat that eh?
- rstnick
06 Apr 2006 20:38
Great news! Thanks for the heads up.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- captaincrusty51
14 Apr 2006 17:34
Want to chime in with another successful install on a 78 KZ650C2. The outlet hose is a little closer to the frame than ideal, but I have not had a flow problem.
Jeff said that depending on the tank clearance could be a problem. This thing is smooth to operate, and now the bike doesn't smell like gas.
To the guys who did this already, how much difference between the stock setup and this before reserve kicks in?
Post edited by: captaincrusty51, at: 2006/04/14 20:36
1978 KZ650C
Keihin CR Special carbs, MAC 4 into 1, Koni Shocks, Emgo Pods
2002 ZRX1200R
Akrapovic exhaust, Teds Ignition Advance, Steering Damper, Dunlop Qualifier tires, Corbin GF/L,Rear tire hugger, Tsukigi braces
2002 ZRX1200R
- giftofthegods77
16 Apr 2006 21:28
You know, I don't really know. I haven't actually run her down that low yet. I have been only riding around town of late...that is until I had my little electrical problem (see electrical forum).
The draw tube, as noted by Chet, does look a bit longer, and I have wondered about this too.
Another thing I've notice is that the bike is much easier to start with the petcock in the prime position. I am sure this is almost always the case, but I never needed to do that before with the stock petcock.
Let me know on the reserve issue.
- giftofthegods77
16 Apr 2006 21:30
Captain,
I like how you mounted the vacum hose nipple down instead of to the side. I bet that worked a bit better. I may even take mine off and switch it around.:whistle:
- captaincrusty51
16 Apr 2006 22:11
I was riding home Saturday when I started sputtering and had to hit reserve. About 9 miles later I filled the tank,and she took 3.8 gallons. I figured I had about 1/2 a gallon or so left in the tank. I reset the trip meter and will get a better idea of usage when it runs out again.
As long as I have 20+ miles of reserve in the tank I won't worry too much about finding a gas station. Anything less than that and interstate trips can get risky.
Overall I am happy I went this route rather than chance rebuilding the stock petcock.
1978 KZ650C
2002 ZRX1200R
2002 ZRX1200R
- sorner
26 Oct 2006 06:08
anybody know if this would work on a 1981 KZ305?
