Fuel leaking
- Indymick
01 Oct 2008 11:18 #239650
by Indymick
1979 KZ650-c3
Fuel leaking was created by Indymick
:dry: Ok I bought a very nive 79 kz 650 c3 had been stored since 88 or at least this was the date of the plate I took off. Long story short as possible rebuilt fuel tap still leaking by when bike is off"vacuum type" and today when I went in the garage strong gas fumes and a puddle gas is coming out of the over flow from the secon carb in from tap. This thing runs great and I hate to think about getting into the carbs right now.
1979 KZ650-c3
- TeK9iNe
- What did you do!?!
- Thank you received: 28
01 Oct 2008 18:31 #239721
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Fuel leaking
I had this problem before. Your carb is simply overflowing due to the petcock leak. Rebuild the petcock with new gasket set, or have it done professionally.
Then it wont flow until you go
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
