GPZ 750 carb on kz650
- odl666
28 Sep 2008 10:58 #239076
by odl666
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
GPZ 750 carb on kz650 was created by odl666
I am currenlty putting a 84 gpz 750 carbs on my 78 kz 650. I am wonering how i will hook the carbs to the fuel tank. There is only one hose that comes out of the gpz carbs and i have two plug ins for the kz 650 gas tank. I know on the kz 650 there is a vacume line. I guess all i need to know is how to get these carbs to work ont he bike. thanks
1979 gs750e
- mtkawboy
- Thank you received: 16
29 Sep 2008 10:48 #239227
by mtkawboy
Replied by mtkawboy on topic GPZ 750 carb on kz650
Get a Y fitting the size you need for the hose. Might reduce flow but thats a bunch of carb for a 650 if its stock
- DrWhizBang
29 Sep 2008 11:03 #239231
by DrWhizBang
KZ650C2 w/810CC in Saint John, NB
-- a sleeper, methinks.
Replied by DrWhizBang on topic GPZ 750 carb on kz650
I think the carbs you are talking about are BS34's. There should be places to connect the vacuum lines on these - but they should have plugs over them. Unfortunately, I don't have a picture to work from - maybe someone else here does?
- odl666
29 Sep 2008 20:48 #239354
by odl666
1979 gs750e
Replied by odl666 on topic GPZ 750 carb on kz650
I am gonna try posting some picks. The carbs have a main hose that goes to the main fuel and a another set of two hoses that are routed form carb one to carb 3 and a hose connecting carb 2 to carb four or something similiar to that.
1979 gs750e
- mtkawboy
30 Sep 2008 11:40 #239461
by mtkawboy
I think mine have rubber caps over vacuum outlets, I use them to synch the carbs {82 GPZ750}
- grinch77
30 Sep 2008 13:53 #239487
by grinch77
1978 KZ650\'82 KZ750 motor
1991 SE-R
Coweta,OK
Replied by grinch77 on topic GPZ 750 carb on kz650
cap the 1,3,and 4 carb take the #2 carb vacuum line to the petcock and the fuel line to the center of the carbs.
1991 SE-R
Coweta,OK
- odl666
09 Oct 2008 16:43 #241001
by odl666
1979 gs750e
Thanks I got it all figured out
1979 gs750e
